1990 CRX Left/Right Blinkers Stay ON Solid (wont blink)
Old Aug 17, 2016 | 07:44 AM
existanzcivicb20's Avatar
Default 1990 CRX Left/Right Blinkers Stay ON Solid (wont blink)
1990 CRX sat for about a week and when I went to work this morning and went into a turn I noticed that my blinkers just stay on solid both right and left. I tried turning on my hazards and it does the same thing. I tried swapping out the hazard button but still same issue. Any ideas??? Could it be the turn signal relay?
Old Aug 17, 2016 | 02:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: 1990 CRX Left/Right Blinkers Stay ON Solid (wont blink)
Replace signal/hazard relay, [flasher], upper left of under dash fuse box, [I think]. 94
Old Aug 17, 2016 | 06:19 PM
thescr33nn4m3's Avatar
This or possibly corrosion inside the light socket.
Old Aug 18, 2016 | 10:05 AM
fcm's Avatar
fcm
Old Fart
Say what? How would corrosion in the light sockets keep the lights on???? 94
Old Aug 19, 2016 | 09:19 PM
Had that happen on a 4dr door I had. Inside the light socket for driver side brake light was caked up corrosion (no idea why). So when I turned the headlights on all the brake lights turned on. Took a handy dandy wire brush and cleared it all out and problem was fixed.
Old Aug 20, 2016 | 07:48 AM
4drEF's Avatar
Keyboard Humorist
So your problem was that when you turned headlights on the brake lights came on?
How is that remotely similar to blinkers not blinking?
Old Aug 21, 2016 | 07:16 PM
I'm not saying my situation is relevant to his, it was simply an example based off the question from FCM.
I'd assume it would be the relay, but I was throwing out a simple two second check. Don't get your panties in such a bunch.
Old Aug 22, 2016 | 09:05 AM
I think my issue is related to moister because it only happens in the morning on my way to work and by the time i get out of work they work correctly (blinking). I did clean all the connectors and sockets but issue still continues. The relay I ordered comes in today so we will see if that will fix it.
Old Aug 29, 2016 | 08:58 AM
FIX: installed the new flasher relay and I have not seen the problem again.
Old Aug 29, 2016 | 03:20 PM
fcm's Avatar
fcm
Old Fart
SURPRIZE 94
Canadian_EF
Jun 10, 2013 09:25 AM
QuikSilverMD
Apr 21, 2011 11:18 AM
da9carl
Audio / Security / Video
Mar 26, 2011 09:49 PM
gnxpro24
Feb 2, 2011 03:52 PM
jade butterfly
Mar 6, 2006 09:13 PM
