what are these...?
Old Aug 13, 2016 | 10:17 PM
Tic55's Avatar
Default what are these...?
can some one possibly tell me what these things are and what they do? this is kinda under the intake piping and right next to the battery..
this is tucked up kinda behind the cruise control. to the far left, behind the intake mani.
Old Aug 14, 2016 | 01:19 AM
holmesnmanny's Avatar
Default Re: what are these...?
The top box is the air intake solenoid. The bottom appears to be the vacuum control box. Without knowing exactly what kind of car it is or what engine it is, it's hard to know for sure.
Old Aug 14, 2016 | 06:31 AM
Tic55's Avatar
Sorry I didn't even think bout putting that, it's a 98 prelude.. base model.
Old Aug 14, 2016 | 07:32 AM
Tic55's Avatar
Also would it be okay to remove both of these?
Old Aug 14, 2016 | 08:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You can remove the intake resonator chamber box but you MUST leave the solenoid screwed to it and plugged in to avoid the ECU throwing a code for it. The device on the firewall is part of the EGR system... again, if you remove it... you will get EGR related codes. Now, if you convert back to an OBD-1 ECU and add a tunable solution, neither device would be necessary and both could be removed.
Old Aug 14, 2016 | 09:16 PM
Tic55's Avatar
I'm boosted, and have hondata s300 with a p28 ecu.... so yea... I'm trying to get rid of abs, and clean up the engine bay of ever every thing I don't need. But thank you.!
Old Aug 15, 2016 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
P28 with S300... yank 'em out !!! Good to go.
tacticalcustoms
Oct 6, 2006 01:17 PM
B-Rizzel
May 11, 2005 03:19 AM
fastludeh22
Aug 25, 2003 04:53 PM
92LudeSI
Mar 3, 2003 03:33 PM
Turbo-Si
Jan 13, 2002 08:42 PM
