Suspension & Brakes Theory, alignment, spring rates....
DC knuckles on EF
Old Aug 13, 2016 | 02:13 PM
CroSi's Avatar
Default DC knuckles on EF
Has anybody here successfully been using DC knuckles ?
Old Aug 13, 2016 | 06:36 PM
Tyson's Avatar
Default Re: DC knuckles on EF
Won't work. Caster and camber all way off.
Don't even bother.
It's been tried.
Old Aug 14, 2016 | 07:55 AM
CroSi's Avatar
Even with adjustable UCA and lowering ?
Don't even bother.
It's been tried.
Old Aug 14, 2016 | 08:14 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You would be better off fitting DA knuckles.
Old Aug 14, 2016 | 09:38 AM
spAdam's Avatar
Loved
Community Favorite
No, DA knuckles are different too.
Adjustable UCAs can't fix completely jacked geometry. There's far more to it than camber & toe.
Old Aug 14, 2016 | 09:48 AM
CroSi's Avatar
I dunno, I just read a few people doing it with no problems.
Old Aug 14, 2016 | 09:58 AM
Tyson's Avatar
why bother asking then?
ignorance is bliss.
do it.
Old Aug 14, 2016 | 10:06 AM
CroSi's Avatar
You got a chip on your shoulder or something ? You need to take it easy buds.
ignorance is bliss.
do it.
Old Aug 14, 2016 | 10:38 AM
Tyson's Avatar
lol.
you were just looking for someone to confirm what you wanted.
too bad.
Old Aug 14, 2016 | 11:47 AM
spAdam's Avatar
Loved
Community Favorite
...that they know of. What Tyson was trying to say is that just because these people did it without being aware of problems doesn't mean they weren't there.
What is the reason for wanting to replace the knuckles? Damaged? Just get replacements for your car. Are you trying to get 10.2" front brakes? Use the correct knuckle from a 90-91 EX (I understand these can be hard to find) or use and adapter bracket like Fastbrakes sells:
Fastbrakes 1984-1995 Civic CX, DX, LX, VX, CRX, del Sol 11" adapter kit with rotors
Old Aug 14, 2016 | 12:27 PM
CroSi's Avatar
I already have JDM ITR front knuckles with new bearings so i'd like to use that for my 5 lug swap but it just seems 5 lug on an EF is too much of a headache anyway. Thanks for the info.
Old Aug 14, 2016 | 12:35 PM
spAdam's Avatar
Loved
Community Favorite
Yeah, if you are doing 5 lug you need the 90-91 EX knuckles and usdm Integra R hubs. The rear is just R&R with the correct arm and spindle.
It's not a headache at all, you just need to use the correct parts.
Old Aug 14, 2016 | 01:03 PM
CroSi's Avatar
It is a headache. The hubs needs go be machined. The machining must be perfect or i'll have bearing failure. And good luck getting a machine shop to do it. Most will refuse to take material off of such an important piece.
Old Aug 14, 2016 | 05:09 PM
spAdam's Avatar
Loved
Community Favorite
You're right, I forgot the hubs have to be ground down.
Old Aug 14, 2016 | 05:54 PM
phunhaus's Avatar
I didn't have a problem with a machine shop turning my hubs on either car - my Integra or my EF. I brought them the hubs I wanted milled, the new bearings, the old hubs and the old bearing races for comparison so they could get the tolerances to OEM specs.
You just need to find the right shop. Thinking about it correctly - there's just as much hub left after the milling as the corresponding OEM hub would have had since the bearing inner diameter and axle outer diameter are stock measurements.
Old Aug 14, 2016 | 08:09 PM
CroSi's Avatar
I will keep this in mind thank you.
Old Aug 14, 2016 | 11:31 PM
Andy@AMR's Avatar
Won't work, not worth the hassle.
EFbattleSedan
Suspension & Brakes
11
Feb 11, 2013 02:41 PM
Snailor Built
17
Nov 17, 2011 12:51 PM
kicken90crxsi
Mar 6, 2011 12:52 PM
allhonda
18
Sep 18, 2007 08:40 PM
Mr.Milton
10
Jun 19, 2007 05:12 PM
