Push button ignition
Old Aug 11, 2016 | 03:10 PM
BSERIESDARRYL's Avatar
Default Push button ignition
So I still have the keys to my car and everything, but yesterday I was having a problem with My ignition. For some reason, when I went to turn the key, literally nothing happened. I know the battery is still good because when I press the hazard lights button, they come on. So anyways, like the idiot I am, I cut the wires behind the ignition switch hoping to test them to see if I could hot wire the car... No luck. So now here I am asking if maybe one of you knew the issue I was having when turning the key. Also, does anyone know a good tutorial for a push button ignition for an Ef? I can't seem to find a good one. Anything helps. I need to get around in this car ASAP.
Old Aug 12, 2016 | 08:55 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Push button ignition
Because google...
The rice way
Push Button Start Wiring Diagram, Wiring Diagram A Simple Wiring Diagram For Push Start Button - Darren Criss
And the right way
crappyshifting
Mar 11, 2012 05:35 PM
turbo-crx
Aug 6, 2009 05:13 PM
turbo-crx
Jan 22, 2009 06:46 AM
windg@t
Nov 8, 2004 04:11 AM
OldSchoolCrxSiR
Aug 22, 2002 09:56 PM
