Need help
Old Aug 11, 2016 | 12:15 PM
Dreams86's Avatar
Default Need help
So i did an engine swap for my 92 honda accord from a f22a2 to a f22b2 but it wont start at all...... So at first i thought it be the starter since it wasnt reaching the flywheel went ahead and bought a new one cor the b2 motor now it does the same thing but this time i can see the engine rotating but wont start help any one please
Old Aug 14, 2016 | 05:47 AM
poorman212's Avatar
Default Re: Need help
Start simple.....are you getting fuel to the rail? Are you getting a good blue spark at the plugs?
Old Aug 14, 2016 | 09:06 AM
Dreams86's Avatar
Im getting fuel just no spark i about tried everything and i still get no spark i checked all my grounds to make sure and everything is connected
Old Aug 14, 2016 | 09:39 AM
GhostAccord's Avatar
So you now know that you have a no spark issue.
Do you have access to a multimeter? What distributor are you using, F22A or F22B? Was it a direct swap or did it require some wiring modifications?
So much better to troubleshoot and test parts in a system vs randomly replacing parts in the hopes that you fix the issue.
You want to test the ignition coil, ICM/ignitor and ignition module. start at the coil and work your way back. There are a number of DIY's that can be found via Google on how to test all of these components.
Old Aug 14, 2016 | 11:31 AM
Dreams86's Avatar
Im using the f22a distributor and it was just a direct swap the only thing i used off the old motor was the distributor and the coil
Old Aug 15, 2016 | 12:11 AM
holmesnmanny's Avatar
Are you using the original harness ?
Old Aug 15, 2016 | 12:44 AM
Dreams86's Avatar
Yes
austinkli
Jun 21, 2014 04:56 PM
hondahatchgsr
Jan 30, 2007 12:11 PM
jeezy
Oct 26, 2006 11:30 AM
hardmoneyhonda
Aug 6, 2005 04:41 PM
