CO 99 Integra GSR Turbo - Sleeved/GT3076/LSD/ Carbon
Old Aug 11, 2016 | 09:24 AM
E85B18's Avatar
Default 99 Integra GSR Turbo - Sleeved/GT3076/LSD/ Carbon
Selling my Garage Kept 1999 Integra GSR - Title in hand
The car has 115k miles. Less than 5k on build.
VIN: TH4DC2397XS002064
Well over $10k invested on top of the price of the car. Many receipts including the build by PFI Speed costing $6,300. Car has been serviced by Rogue Cars in Boulder.
83mm PFI Godzilla Sleeved Block
Airas 83mm Pistons
Eagle Rods
MFactory LSD
ARP Head Studs
1000cc Precision Injectors
Walboro 255LPH Fuel Pump
Hondata S300
Hondata 4 Bar MAP Sensor
MSD 6A Ignition
Stage 5 Competition Clutch
Garrett Dual Ball Bearing GT3076
Spearco Intercooler
50mm Tial BOV
Precision 39mm Wastegate
3" Thermal Research and Development Exhaust
Magniflow Cat
3" Test Pipe
New Radiator
New battery
Catch can / crank case ventilation
H&R Race Springs
Tokiko 5 way Adjustable Shocks (ride height adjustable)
SPC Performance Camber/Caster plates (Front and Rear)
Whiteline Racing 22mm Rear Sway Bar
5% Tints
Short Shifter
Rockford Fosgate 6 1/2" Component Front Speakers
Alpine Type R 6.5" rear speakers
Viper Paging Alarm System w/ Remote Start
VIS Carbon Fiber Hood (Garage Kept - Looks new, no fading or color)
VIS Carbon Fiber Hatch (Garage Kept - Looks new, no fading or color)
Paint and interior are on par with a well-respected garage kept car built in 1999
Prologger electronic boost controller with wideband O2 sensor and “never-lean” technology. This data logs RPM, boost, and AFR.
Tuned on E85 - Car makes 490whp on a low reading Mustang dyno at 28psi. I run less boost on the street, 28psi blows the tires off.
I have the OEM Integra “blade” wheels
Full set of 15” XXR 551 wheels with new summer tires (x2) and 15” slicks (x2) - Basically brand new
I have 3 of the 10 spoke 18” wheels. One was damaged in a construction zone.
I have the OEM rear wing
The bad:
Ride height is set high to fit tall tires, can easily be lowered
No Air Conditioning - could be installed
One low beam headlight is out
Speedo doesn’t work
Car was rear-ended ruining the hatch which is why I bought the carbon hatch
When I have time I’ll replace the headlight and VSS sensor to get the speedo to work.
Priced at $9,500
Email or PM with questions - stout959@gmail.com
Old Aug 22, 2016 | 07:45 AM
E85B18's Avatar
Default Re: 99 Integra GSR Turbo - Sleeved/GT3076/LSD/ Carbon
Bump it up - Offers considered..
Old Sep 6, 2016 | 08:27 AM
E85B18's Avatar
Bump
Old Sep 8, 2016 | 11:39 AM
Civic92Turbo's Avatar
if you decide to part, I would like the carbon trunk... I am also located in boulder... Bump for Colorado Rep
Old Sep 9, 2016 | 09:39 AM
E85B18's Avatar
I'd like to sell it as is but I'll let you know if I part out. Thanks
Old Sep 9, 2016 | 10:50 PM
jimmy051702's Avatar
so how open are you my number is 915 246 4847 you can keep the wheels
Old Nov 30, 2016 | 01:03 PM
E85B18's Avatar
Bump it up..
Old Dec 3, 2016 | 03:39 PM
E85B18's Avatar
Sale pending
E85B18
Jun 22, 2016 04:45 AM
ntensegsr
Jan 18, 2011 07:14 PM
99turboedsi
Sep 24, 2006 05:57 AM
92HB_HB
May 1, 2005 05:22 AM
