JDM Header/Bracket Install Q
Old Nov 8, 2002 | 04:02 AM
N1Spec's Avatar
New User
Default JDM Header/Bracket Install Q
hi guys, just recieved my JDM header......
now in the below pic, the parts you see....... is that all the parts required for the install, minus the cat of cos.
another Q to those who have the bracket: do they come with bolts? becos mine doesnt have any.
[Modified by N1Spec, 1:03 PM 11/8/2002]
[Modified by N1Spec, 1:04 PM 11/8/2002]
Old Nov 8, 2002 | 04:04 AM
DutchITR1689's Avatar
Default Re: JDM Header/Bracket Install Q (N1Spec)
You can reuse the bolts that are holding your old bracket...
[Modified by DutchITR1689, 2:10 PM 11/8/2002]
Old Nov 8, 2002 | 04:19 AM
N1Spec's Avatar
New User
Default Re: JDM Header/Bracket Install Q (DutchITR1689)
ok call me a newb...... but is this how the donut is supposed to sit??
Old Nov 8, 2002 | 04:20 AM
Willard's Avatar
just make sure that you get a longer bolt for the hole in the bracket that has the thick washer.
Willard's Avatar
Old Nov 8, 2002 | 04:21 AM
Back in Black's Avatar
Rather OG
yes
Old Nov 8, 2002 | 04:28 AM
N1Spec's Avatar
New User
Default Re: JDM Header/Bracket Install Q (Jason Franza)
cheers fellas!
im just alittle excited to get the thing on! dont want to f#5% it up!
Old Nov 8, 2002 | 04:31 AM
Willard's Avatar
Old Nov 8, 2002 | 04:36 AM
Default Re: JDM Header/Bracket Install Q (Willard)
Willard, why didn't you remove the old bracket? Mine was touching the header (=rattles)...
Old Nov 8, 2002 | 04:40 AM
Willard's Avatar
that is Pat's old car...
I think it was pushed towards the oil pan and did not rattle.
I have the JDM hanger and enjoy it.
Old Nov 20, 2002 | 08:13 AM
jappwr's Avatar
Where can I find the donut needed to bolt-up/install my JDM header? How much should I be looking to spend? Thanks in advance for your help. .
Old Nov 20, 2002 | 08:17 AM
Default Re: JDM Header/Bracket Install Q (jappwr)
Go to your Honda dealer, it's the same as the S2000 donut...
Old Nov 20, 2002 | 08:18 AM
Chris N's Avatar
S2000 donut. I have one, if you want it.... im me.
I reused my usdm header bracket with my dc jdm header. No problems, no rattles, bracket hasn't broken, nothing. You can reuse the bracket bolts you have, btw....
Old Nov 20, 2002 | 08:38 AM
itr1244's Avatar
Default Re: JDM Header/Bracket Install Q (1107)
i have jdc dc 4-1
and got the header bracker but it didnt fit. the holes dont even line up
Why is that
[Modified by itr1244, 5:38 PM 11/20/2002]
Old Nov 20, 2002 | 08:42 AM
SurferX's Avatar
Default Re: JDM Header/Bracket Install Q (itr1244)
The DC JDM header is designed to be used with the 96-spec bracket (USDM) so there is no need to get the JDM 98-spec header bracket. My DC JDM did end up tearing through the stock bracket after a few months though so I ultimately had to just remove the bracket anyway.
Old Nov 20, 2002 | 08:52 AM
baonest1's Avatar
whoa seriously... how much do they run?? i might jus have to do that.
Old Nov 20, 2002 | 09:18 AM
Tweakmeister's Avatar
Default Re: JDM Header/Bracket Install Q (baonest)
more pics here if you need them...
http://www.hogens.com/car/default.ph...ader/index.php
Old Nov 20, 2002 | 09:58 AM
jappwr's Avatar
Default Re: JDM Header/Bracket Install Q (Tweakmeister)
Thanks for the help
Old Nov 20, 2002 | 02:34 PM
itr1244's Avatar
Go to your Honda dealer, it's the same as the S2000 donut... whoa seriously... how much do they run?? i might jus have to do that.
They were like 50 something Canadian
But the bracket not fitting is nothing has to do with the header. the bracket wont fit the CAR
silentdeath12886
Oct 28, 2006 08:37 PM
Another_Teg_Owner
Aug 3, 2002 09:53 AM
onyx00
Jul 2, 2002 10:27 PM
onyx00
Aug 18, 2001 07:20 PM
FBP_1171
Jun 18, 2001 07:11 PM
