Cruise control not working after b20 swap
So I just did a b20 swap on my eg8. Love it. Very quick, and responsive. But! My cc doesn't work.. And it did before the swap.
I'm using my stock harness from the eg. 95 Ls Ecu. I have everything hooked up I believe, unless there's something I'm
missing..if anymore info is needed lmk. Also tach isn't working either but I'm pretty sure it's that blue wire on the dizzy everyone
talks about, and for that I just splice a wire from the blue wire on the dizzy to the blue wire on the drivers side under hood right?
anybodys input will be greatly appreciated. Thank you
What ECU are you using? It should be stamped or printed on the shell somewhere, if you know what ECU it is you can normally find a wiring diagram for it / pin-out and then instead of splicing into the dizzy you could run another wire from ecu > clock loom and have a little less mess.
Can you help me install crui control for Honda Civic 2013 gen 9? I have connected the Crui control switch and turn on the Crui Main on the TACH dashboard. But set crui doesn't work while vehicle speed 45 km/h.
TKL
May 15, 2003 08:36 PM
