Extended ball joints in stock somewhere?
Old Aug 8, 2016 | 12:34 PM
The sweed's Avatar
Default Extended ball joints in stock somewhere?
I need som extended ball joint for my civic -88 hb. The traction bar is way too close to the crank pulley and I like that it corrects rollcenter for roadracing.
I only know buddy club and Jīs racing that makes them. And the civic 92-00 has a differant tapper in the lower control arm for the ball joint so I donīt want those.
Everywere I look they donīt have them in stock and they are on backorder for a long time.
Is there anyone that knows someone that has them in stock??
Old Aug 9, 2016 | 11:21 AM
Tyson's Avatar
Default Re: Extended ball joints in stock somewhere?
Those extended ball joints only make the roll rate worse, not better.
I've not heard the EG ball joint has any different taper. I think ppl would have mentioned it a long time ago when errantly swapping knuckles. EG knucles dont work on EF but for different reason.
Basically an extended ball joint is not the fix you're looking for.
churn dasher
Jun 4, 2010 06:04 AM
Powered by VTEC
Jan 1, 2008 10:51 AM
scsheong
Nov 11, 2004 06:44 AM
wdskuk
10
Feb 14, 2004 04:40 PM
SleeprCivic
Aug 20, 2003 08:27 PM
