Has anyone reduce the weight of there stock flywheel?
Old Nov 8, 2002 | 01:12 AM
RExLUdER's Avatar
Default Has anyone reduce the weight of there stock flywheel?
I just dropped my Tranny and I am looking for one. If you know anyone that is selling one Let me know. But I want to know if any has reduced the weight of there flywheel...What were the results
Old Nov 8, 2002 | 04:07 AM
apexii's Avatar
Default Re: Has anyone reduce the weight of there stock flywheel? (RExLUdER)
Don't do it. Honda does not advise of it being done, it was not intended to be modified. ACT was modifying oem flywheels until problems popped up, now they do not anymore. I had one and it was complete ****.
Spend $295 on a fizdana/clutchmasters.
Old Nov 8, 2002 | 02:34 PM
pentaq's Avatar
Default Re: Has anyone reduce the weight of there stock flywheel? (apexii)
where 295?
pentaq
Old Nov 8, 2002 | 02:48 PM
Mike95lude's Avatar
I had the ACT flywheel that Apexii is talking about also but I experienced no problems and as long as the "shaving" of the flywheel is even and conservative with proper balancing I see no reason to advice against doing so. I still have the ACT flywheel on my spare H22A1 engine and very likely will be using it again.
Results of the flywheel were better throttal response and quicker revs in the lower gears.
[Modified by Mike95lude, 3:49 PM 11/8/2002]
Old Nov 8, 2002 | 08:33 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Has anyone reduce the weight of there stock flywheel? (Mike95lude)
just buy a clutch masters... mine is 8 lbs, i noticed a major improvement in reving when i put it on, and i honestly didn't expect it
Old Nov 8, 2002 | 08:42 PM
PrecisionH23a's Avatar
Default Re: Has anyone reduce the weight of there stock flywheel? (Boosted97Lude)
i just took off 5lbs from my stock one, couldnt tell the difference because i did a WHOLE bunch of other mods as well as the flywheel.
Old Nov 8, 2002 | 09:09 PM
BoostedH23a1's Avatar
Default Re: Has anyone reduce the weight of there stock flywheel? (GudeH23a)
i have the ACT its 14 pounds. (stock lightned) i like it except for no timing marks.
Old Nov 9, 2002 | 04:34 AM
apexii's Avatar
Default Re: Has anyone reduce the weight of there stock flywheel? (BoostedH23a1)
That's strange, both of my act flywheels had marks?? Do a lot of drag racing and kiss that baby goodbye.
Old Nov 9, 2002 | 06:16 AM
ive been draggin since i got the car 2.5 years ago
Jabinya
Apr 21, 2007 05:11 PM
fled
Jul 5, 2006 12:06 PM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
yellowbuffalo
May 19, 2003 07:05 PM
IdotheSHOCKER
May 23, 2002 03:10 PM
