civic trailing arm on integra with integra wheel hub/bearing?
Old Aug 5, 2016 | 02:16 PM
2slowIntegraLS's Avatar
Default civic trailing arm on integra with integra wheel hub/bearing?
I bent my passenger side trailing arm on my dc4 integra. I need to get it back up and running asap so I am considering everything. I can't find a good integra trailing arm within a reasonable distance but there are some civic trailing arms locally... Here's the main question. Can I use a civic trailing arm, install a new integra rear wheel hub/bearing, and then transfer brake parts i.e. caliper mounting bracket, caliper, rotor, etc... Will this work or not and does it matter if the trailing arm originally came with drums or discs? I have searched a lot but cannot find this addressed directly. I have read that the trailing arms are the same but I'm still not sure if this will work... any insight is appreciated, Thanks.
mofo951
Suspension & Brakes
Mar 10, 2012 12:23 PM
bigoh22
Jul 27, 2010 10:18 AM
SUP!reme
Sep 21, 2008 07:11 AM
young geezer
Mar 10, 2008 04:20 PM
Badger401
Aug 21, 2004 09:14 AM
