I am parting out my 1998 prelude 5 speed with clean title 85k miles, car is perfect inside out and I have proof the chassis has 85k miles, no dents no accidents selling chassis with current reg engine transmission, no bumper, hood, fenders, shift linkage, ecu, headlights, shocks, and it will have spare wheels for $500. Below is a parts list, I have alot more parts than are listed let me know what you need 925-321-5289
Engine h22a1 with darton mid sleeves, cp 88mm low compression pistons for turbo, eagle rods, arp studs, oem valvetrain, aem cam gears, manual tensioner, engine only has a few thousand miles, complete oem intake manifold with all sensors and injectors, header pickup only for $1500 firm $450 for the head
turbo kit garrett .60 .63 turbo with turbo blanket, drag turbo manifold just painted a/c compatible, downpipe, dump tube, turbonetics wastegate, greddy bov, intercooler and piping, mac boost solenoid, oil lines, complete kit $1200
Aem series 1 ems with cables $600 shipped
rc injectors 550cc with wiring $225 shipped
h22a4 stock distributor with coil $75 shipped
jdm distributor 1 plug 8 wire with custom harness to delete the crank angle sensor $100 shipped
thermostat housing with thermostat $50 shipped
timing gears with crank angle sensor $60 shipped
timing covers $60 shipped
msd 6a ignition 6200 with blaster 2 coil $100 shipped
M2l5 transmission has light grind in third and repair on the side of the transmission from axle hitting $200
Stock intake manifold complete with throttle body and iacv all sensors, egr ports were cleaned out and plugs replaced $160 shipped
Tokico blue shocks with eibach ground control coilovers like new $380 shipped
Guage cluster 85k miles $120 shipped
Shift console and cables $125 shipped
dc sports exhaust $200
innovative mounts sides and rear $140 shipped
power steering pump $70 shipped
let me know what other parts you need 925-321-5289
Edit:accidently posted it twice from my phone, sorry mods
where are you located? Whats the Compression ratio? how much power were you getting off this build? what specifically is done with the valvetrain? sorry for all the questions but I am interested just need alil more info thanks! you can text me if you like as well 646-431-131four
