93 Del sol - Why does my passenger window motor have a 4-pin connector?
Old Aug 4, 2016 | 12:30 PM
Goodguy889's Avatar
Default 93 Del sol - Why does my passenger window motor have a 4-pin connector?
hey guys I have a 93 Del sol and the passenger window motor went out. Simple fix but here's the deal. The motor and the harness on the door is a 4 prong connector. Everything I've ordered and search shows the passenger side is a 2 wire connection. Is this normal and where can I find a motor to fit and connect?
Old Aug 5, 2016 | 06:27 AM
Former User's Avatar
Default Re: 93 Del sol - Why does my passenger window motor have a 4-pin connector?
Are the 4 wire colors in the connector identical to the driver's side window motor? If so, it appears that the same 4-pin motor is used on both sides but only two of the wires are active on the passenger side.
http://www.hondaautomotiveparts.com/...ry5=DOOR+GLASS
Neth
Jan 19, 2018 02:14 PM
marcelosm
Apr 5, 2014 09:28 AM
jkub23
Jan 17, 2008 03:07 PM
91-lsvtecsi
Jul 8, 2007 04:42 PM
