1994 Honda Accord Manual - No start, no crank... Sometimes.
Old Aug 2, 2016 | 01:28 PM
vtec.yo.1316's Avatar
Default 1994 Honda Accord Manual - No start, no crank... Sometimes.
My 1994 Honda Accord with the manual transmission and the 2.2 liter v tec sometimes will not start, or crank. All of my dash lights and my radio will come on, and I have recently done a new starter, new battery and new battery cables, new alternator, and a new ignition. I'm at a total loss. If I push start it, it will get me going and then it will start fine until the next time (happens every day, every couple of days). Is there any fuses or relays that it could be? Help!
Old Aug 2, 2016 | 08:53 PM
holmesnmanny's Avatar
Default Re: 1994 Honda Accord Manual - No start, no crank... Sometimes.
It's possible if you have an aftermarket alarm for the ignition kill function of the alarm to be bad. It's especially more likely if you have a Viper alarm.
Old Aug 12, 2016 | 10:19 AM
bantum1cwa's Avatar
Go over your repairs and be sure you have securely reattached all your ground cables for the components you touched. I had an intermittent no start no crank and after three weeks of testing, found a ground connection nut that was on but not snug enough causing intermittent grounding.
StuckInTexas
14
Aug 27, 2018 12:57 PM
dwkirch
Mar 12, 2016 03:00 PM
herc8000
Jan 15, 2016 06:29 AM
Miridion
Oct 19, 2015 05:34 PM
