NY 2000 Civic Si EM1 Built B18C-R Spoon Volks etc
Old Aug 2, 2016 | 09:36 AM
ricb20vtec22's Avatar
Default 2000 Civic Si EM1 Built B18C-R Spoon Volks etc
Up for sale is my EM1 Si that is tastefully modded. I have owned the car for about 4 years now and have pretty much put it together myself. The car sports it's original paint which does have it scratches and dings here and there but nothing major. It does have a NY Salvage / Rebuilt Title due to previous theft. However, every single VIN panel still matches including the original hood which will be included in the sale. I put the car together as a cruiser / Auto-X vehicle but I have lost my passion for it and my priorities have changed a bit. As you can see from the photos the car was put together the right way all with quality parts. No corners were cut. I am flexible on the price however, any lower & parts start coming off.
Engine / Drivetrin :
96 Spec JDM ITR full swap ( engine, trans, shift linkage etc ) - $3300The engine fully rebuilt by EnDyn & had some mods added while it was apart.
The mods go as follows
:81.25MM 11.5:1 Compression EnDyn Roller Wave Pistons
Manley H-Beam Rods
All new OEM Honda Bearings
EnDyn Modified ITR Oil Pump
Moroso Oil Pan
Fluidampr Street Crank Pulley
ARP Headstuds
Cometic .036" Headgaske
tAll new seals crank, cams, etc every single seal on the engine
Block was bored, honed, line-honed & the entire reciprocating assembly was balanced
The above work & parts $4800
The Cylinder head was also done at EnDyn, the head work goes as followsFull Port Job - cleaned, CNC port job, hand finished ports, decked, new bronze valve guides, etc $1400
Supertech Flat Faced Valves, Dual Valve Springs, titanium retainers - $600
Jun 3 Cams - $1000Jun Adjustable Cam Gears - $350
Whitfield Custom 4-1 Header w/ megaphone / reverse cone & 3in v-band collector - $1350
ITR Intake Manifold cut / port / welded also done by EnDyn - $450
ID 1000CC Fuel Injectors - $400
Hondata Intake Manifold Gasket - $50
AEM Fuel Rail - $100
AEM Adjustable Fuel Pressure Regulator - $150
Toda Timing Belt - $200
Spoon Radiator Hoses - $300
Spoon Thermostat & Fan Switch - $200
Avid Motor Mounts
Mishomoto Radiator & Slim Fan
Braided Stainless Steel Fuel & Clutch Hoses
Custom 3in Cold Air Intake
BYP Racing Titanium Full Exhaust - $1100 weights almost nothing but is loud!
Exedy 9lb flywheel & Stage 2 Clutch - $600
P28 ECU w/ Hondata S300 tuned by Chris Harris of Xenocron
There's more that I forgot but you get the picture, just in the engine bay is over $18k
Less than 2k miles on the engine rebuild, it runs strong & no smokes or weird noises what so ever.
Suspension:Tein Curcuit Master Coilovers 22k front 14k rear - $3000 & these are custom order & a 6 month wait. Rides stiff but handles like a go-kart
Function 7 Rear Lower control arm w/ spherical bushings - $450
Skunk 2 front & rear Pro Series camber kits
ASR 32MM hollow sway bar complete kit ( gold brace, sway bar, end links etc. ) - $700
Spoon front lower control arm bushingsBeaks Rear lower tie bar
Spoon Front & rear strut tower bars
SPC Rear toe adjusters
Over $5k in suspension
Wheels & brakes
CE28N 16x8 +42 Bronze w/ center caps - $3000
Bridgestone Potenza RE-040 tires still like new all around - $800
ARP Extended Wheel studs up frontMuteki open ended lug nuts in titanium
Spoon Monoblock front calipers w/ matching rotors w/ Honda Pads - $2000
Stoptech rear cross drilled rotors w/ Hawk HPS + padsRussel stainless steel brake lines on all 4 corners
Over $6k in wheels & brakesExteriorBYS Front bumper painted to match car does have small crack on passenger side as pictured! - $1100
ARC front winglets do have some scuffs underneath but nothing major - $400
Mugen Rear Wing - $900
OEM Rear Lip, discontinued & very hard to find now - $400 I also have the oem front lip which I will include in the sale
Oem front mud flaps, I do not have the rears got the car like that.
OEM CTR Headlights w/ city lights - $800
Spoon CF Hood - $1100
About $5k in exterior
Interior
Pretty simple & clean
Front seats will be a choice of either the Spoon Reclineable seats that are pictured which are discontinued & extremely rare or a set of Recaro SR5 Wildcat seats in yellow
Has OEM radio block off plate, no audio system including speakers
Has passengers airbag delete tray
OEM Rear SeatsTakata Drift 3 Harnesses
CTR shift boot
CTRX Pedals
Sergeant adjustable dead pedal
CTR Floormats
Spoon Cluster & Steering wheel will NOT be included in sale. I can sell them, but for the right price.
I know that there is plenty more that I have forgotten but you get the point, it was put together right & taken care of. I know my price is expensive but as you can see you can't put together 1/2 of those car with that, so I believe I am being fair. Like I said, I am flexible on the price but parts will come off.
I am asking $11,500 w/o the Gen 1 Steering wheel or $12,500 w/ the Gen 1 Steering wheel.
Please Call / text me at 914-282-2304, I am rarely on here so this is best way to reach me.
Old Aug 2, 2016 | 12:58 PM
mosthated's Avatar
Default Re: 2000 Civic Si EM1 Built B18C-R Spoon Volks etc
Looking pretty sharp too bad I almost had to break my neck to look at photos lol. maybe a tad bit much in price but overall nice freakin ride GLWS!!!!
Old Aug 2, 2016 | 02:11 PM
I know it's expensive, but you can't replace it for that even if you tried. That's why I included prices on most of the stuff, add it up and you will see.
Old Aug 2, 2016 | 03:59 PM
official_del-sol's Avatar
That's actually a cheap price , if you part out the front spoon seats im interested or for trade plus cash for a recaro spg bucket seat
Old Aug 2, 2016 | 05:32 PM
youra6's Avatar
Too bad its a salvage title. Looks clean, glws!
Old Aug 3, 2016 | 01:25 AM
I don't have the time to ship them. I just want the whole car gone
Old Aug 3, 2016 | 02:56 AM
I'm located In NY so no need to worry about shipping let me know
Old Aug 3, 2016 | 03:00 AM
bump
Old Aug 3, 2016 | 07:09 AM
ShinsenTuner's Avatar
No Jodas
Damn.
Old Aug 3, 2016 | 07:36 AM
mosthated's Avatar
yes I do see and wow such a nice car!!!
Old Aug 3, 2016 | 03:02 PM
Thank you
Old Aug 4, 2016 | 03:06 AM
bump
Old Aug 4, 2016 | 04:25 AM
danteisme's Avatar
Loved
Community Favorite
Lots of top notch parts here, good luck sir!
Old Aug 4, 2016 | 05:30 AM
mosthated's Avatar
bump for awesome car needs good home!!!
Old Aug 5, 2016 | 02:31 PM
Thank you!
Old Aug 6, 2016 | 03:03 AM
do not contact me if you are not 100% serious. do not waste my time
Old Aug 9, 2016 | 01:34 AM
Bump
Old Aug 9, 2016 | 03:16 PM
Bump considering part out. Is anyone interested in the swap?
Old Aug 9, 2016 | 04:53 PM
I want the seats
Old Aug 10, 2016 | 12:59 PM
mosthated's Avatar
don't do it maybe seats but don't part out anything else
Old Aug 10, 2016 | 01:14 PM
If it doesn't sell soon I have no choice
Old Aug 12, 2016 | 01:14 PM
Bump
Old Aug 14, 2016 | 09:43 AM
dave7's Avatar
10 Year Member
I'd be interested in the spoon calipers if you sell them.
Old Aug 15, 2016 | 08:10 AM
Bump
Old Aug 18, 2016 | 01:24 AM
Bump
