2012 Honda Pilot Touring 2wd electrical issues..
Just discovered that i have several issues with my pilot. Any input would be greatly appreciated.
issues are as follows:
-Unable to open rear hatch with button on driver door/outside hatch door.
-Unable to open rear hatch glass with outside hatch button.
-Unable to remotely roll windows down by holding unlock button on key fob.
-Hear an "unlocking sound" inside driver door immediately after driver door is shut.
All fuses in 3 fuse locations are good.
So basically, for the time being i can only open the rear hatch with my key fob only, but, i lost all control to open the glass.
Again, im thankful for any help before i get reamed at the dealer.
You need to get a wiring schematic from something like a Haynes manual and see what wires all those buttons share that are the same between the switches. If they share a common ground, power, signal or relay it could definitely cause this issue to happen. Don't know how handy you are but if your not handy with electrical then go to a shop that is good in electrical diagnosis. Dealership is great at replacing parts but not diagnosing correctly.
92civicsi05
Nov 14, 2006 08:32 AM
