Shorter bleeder screw on clutch slave cylinder?
Old Jul 31, 2016 | 04:53 PM
Angelsbeamer's Avatar
Default Shorter bleeder screw on clutch slave cylinder?
So I am building my b18c1 turbo and I have A ram horn turbo manifold and the turbo hits the bleeder screw on the slave cylinder. Does anyone know if I can swap the bleeder screw for a shorter one from another car? If I clock the turbo more the intake pipe will hit the radiator. Any help would be appreciated. Thanks
Old Jul 31, 2016 | 10:02 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Shorter bleeder screw on clutch slave cylinder?
I think I would see if you could get away with shaving the nipple off the bleeder screw. Not sure if you can but that would be better (if it works) than switching to a flat head bolt to plug the bleeder hole. Flat head bolt would make it a real PITA to bleed and purge the clutch slave cylinder.
Old Aug 1, 2016 | 05:31 AM
Yeah I was thinking that too but want to see if there is a better option.
Old Aug 1, 2016 | 04:08 PM
Here is what I am thinking. I can't put this M7 nut on there, weld it to the top of the bleeder and cut off the nipple. I can clean it up and make it look pretty decent. What do you guys think?
It still gives me clearance under the nut which you can see and the bleeder is screwed all the way in.
hawtsoss
Oct 21, 2008 03:39 PM
GetupHeights
Sep 21, 2005 05:52 PM
superfuji57
Sep 28, 2004 08:22 AM
Kool Blue Lude
Sep 9, 2003 04:43 PM
2000BoostedEX
May 8, 2003 08:47 PM
