Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
o2 sensor problem
Old Jul 30, 2016 | 08:20 AM
peterkemp47's Avatar
Default o2 sensor problem
03 accord LX coupe, V6 250,000 miles
(Note: I posted this in another forum that may have been the wrong place. Looks like there's more activity here. Hope someone has an answer.)
Check engine light on for quite a while. Just replaced the upstream o2 sensors hoping this will fix problem. Check ODB and the readings for the new sensors appear to be in range. But the ODB program is reporting that both the bank 1 and 2, second sensors are reporting no electrical contact with the sensors. This makes me think that maybe there's a wiring problem more than problems with the sensors themselves.
What would cause this and where is a good place to start looking for the problem. Or is it possible that both downstream sensors are bad and causing the no voltage error code.
How hard is it to change these sensors? Upstreams were easy other than spending more time than needed trying to get the connectors to release. I think those things were designed by the devil.
Old Jul 30, 2016 | 09:29 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: o2 sensor problem
Post the actual trouble codes, that may help narrow the issue.
Old Aug 1, 2016 | 06:11 AM
After installing the new O2 sensor, I tried to clear the trouble codes but they wouldn't clear which makes me wonder if they are permanent codes. So I disconnected the battery. Still waiting to get past the initial period before I can take it for inspection but so far no check engine light. I'm hoping those were old codes that were fixed by the new sensors.
Old Aug 5, 2016 | 07:31 AM
Okay the CHL has come back on and I just checked the codes. I'm getting P0420 and P0430 codes. These codes indicate catalytic converter failure but I'm wondering if I should try replacing the downstream O2 sensors before going to the expense of changing the cats (there are 2 of them on this V6). Opinions?
Old Aug 9, 2016 | 12:53 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
If the vehicle is in closed loop and proper fuel control,replace the cats.
Old Aug 10, 2016 | 10:24 AM
NotARaCist's Avatar
I never narc'd on nobody!
Before you go replacing the cats, check for exhaust leaks/cracks in the cat, especially near the flange and the secondary O2 sensor.
Old Aug 11, 2016 | 01:38 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Agreed,hence my advice of making sure the vehicle is in proper fuel control.
Exhaust leaks will be reflected in the fuel trim/O2 data PIDs.......
peterkemp47
Jul 30, 2016 07:10 AM
92_b20_eg
Mar 7, 2008 10:38 PM
crf450ex
Feb 26, 2006 07:15 PM
krazy one
Nov 18, 2005 02:12 AM
want2rally
Oct 9, 2005 09:37 PM
