1997 civic ex; car won't start possible alarm problem?
Old Jul 28, 2016 | 05:11 PM
p0cky's Avatar
Default 1997 civic ex; car won't start possible alarm problem?
Hello,
Since two days ago, my civic has had some trouble starting. When the key is turned to the on position, lights on the dash will light up; however, when I turn it to crank the engine, all power seems to shut off. Once I close the driver side door, the car alarm will start to go off. Pressing the unlock on my keyless entry seems to silence it. I have tried pressing and holding the valet button until the alarm goes off for about a second, but power within the car seems to cease once I try to crank the engine. Yesterday I removed the negative terminal connector on the battery, reattached it, and it started up. Anyone have any ideas? Thank you.
Old Jul 28, 2016 | 06:01 PM
Former User's Avatar
Default Re: 1997 civic ex; car won't start possible alarm problem?
The ON(III) key position is designed to turn off power to some sources.
If the starter is not cranking, check whether the rubber stopper on the clutch pedal fell out.
https://honda-tech.com/forums/honda-...arter-3282287/
Old Jul 29, 2016 | 11:38 AM
p0cky's Avatar
Do you have any pictures of this rubber stopper and its location? I did manage to find pieces of rubber in the car floor near the clutch
EDIT: From my understanding with the thread you posted, this is clutch pedal switch B and this is where the rubber stopper goes? Can't seem to see clutch pedal switch A since it is kind of obstructed. I just found switch A. I felt around the rubber and it seems to be intact still. I'm assuming if switch A is held down the car will crank? Should I hold switch A down with my finger and try to start the engine? Pieces of rubber as mentioned: Imgur: The most awesome images on the Internet
Old Jul 29, 2016 | 01:50 PM
chrysler kid's Avatar
In the picture background you can see the neutral safety switch. The one you took a picture of is the depression switch for the cruise control
Old Jul 30, 2016 | 09:06 AM
fcm's Avatar
fcm
Old Fart
Honda Automotive Parts
When you say "all power" does that mean dome light, [if on] also goes out?
If so, check your main grounds, batt. post. batt. to chassis and chassis to engine grounds, DO NOT just eyeball the, disconnect/clean/reconnect. 94
Old Jul 31, 2016 | 02:05 PM
p0cky's Avatar
Thank you guys very much for your input. I was going to clean the terminals and it seems that the positive wires were loose as they came off when I tried to take out the battery. I simply just unloosened the terminal, put the wires as far as I could inside the terminal, and then reconnected the battery. The car started on my first try, and hopefully it wasn't some dumb luck.
Oneofnine
Nov 29, 2014 11:23 AM
Cameron k.
13
Jul 9, 2012 07:46 AM
speed_bumps_suc
Audio / Security / Video
Feb 28, 2010 06:26 PM
Dan Fizzle
Jun 19, 2006 07:06 AM
Junkyard2000
Jul 4, 2005 10:08 PM
