SUSPENSION
-Ground Control sleeves
-koni orange F, KYB Rears
-350lbs F, 400lbs R springs
-ADJ rear camber arms
-Front CUSCO STRUT BAR (NOT PICTURED)
-Rear EM Racing strut bar
-ES rear trailing arm bushings
-Front HARDRACE upper control arm bushings
-ES REAR control arm
Bushings
-new inner and outer tie rods
-front SI sway bar
-rear ST 22mm rear seat bar with stephetical end links.
DRIVETRAIN
-HASPORT Linkage conversion
-ES SHIFTER BUSHINGS
-B&M short shifter
BRAKES
-Front and rear INTEGRA DA disc brakes
-DA booster and master cylinder
-DA prop valve
-civic EX knuckles with new pressed in wheel bearings
-new brake lines
EXTRA PARTS
-DC HEADER (not on car)
-new slotted and drilled rotors for rear with pads
-HASPORT HYDRAULIC MOUNT
-B16a ECU
-B&M adj. fuel pressure reg.
-VTEC SUB HARNESS
ALL WILL BE FREE UNLESS I SALE
-hero sport shift extender
Have many more part in car. Most of the parts were installed new back in Novemeber along with the swap. Wired for subwoofer and amp as well.
CONS
-typical door dings for an older car
-previous owner put some sealant around windshield
-drivers window sticks when getting to the top.
-Needs front axles, boots are torn
-driver seat ripped
-exhaust rubs sometimes.
Car is not perfect but it drives great and make a great commuter car. I'm asking 3,700 or reasonable offer. Thanks
Reason: Updated price and link
