Front caliper help stat!!!
Old Jul 27, 2016 | 01:05 PM
Aquila's Avatar
Default Front caliper help stat!!!
Hey guys, im currently changing out my axles and front driver brake caliper. the bleeder valve was broken so i went and bought a replacement but only bought the half with the valve on it. how do i take the old mounting bracket off? There is a metal cap piece on one end and a bolt on the other. I removed the bolt but cant seem to figure out the metal cap part. Sorry no pics, currently having a new phone shipped in as my last one it broken.
Old Jul 27, 2016 | 01:50 PM
Aquila's Avatar
Default Re: Front caliper help stat!!!
Bump, my car i currently on jacks. help is appreciated.
Old Jul 27, 2016 | 02:05 PM
testify's Avatar
On vacation
Are you talking about the slide pins?
Just slide it.
Old Jul 27, 2016 | 02:10 PM
existanzcivicb20's Avatar
if it does not slide out it means the pin is seized is there you will need to work the caliper from side to side to make the pin rotate or even easier use a torch to heat up the bracket on the side that the pin is seized.
Old Jul 27, 2016 | 02:34 PM
Aquila's Avatar
oh ok, thanks dudes, just wanted to make sure i didnt break anything
Old Jul 27, 2016 | 03:18 PM
Aquila's Avatar
ok, no. ive gotten in pretty far and now its just stuck as if there is a little lip keeping it in
Old Jul 27, 2016 | 03:37 PM
testify's Avatar
On vacation
The caliper should slide right off.
Are you soaking it in penetrating fluid?
Old Jul 27, 2016 | 05:14 PM
Aquila's Avatar
i just fixed the current caliper. thanks for the help though, dudes.
Old Jul 28, 2016 | 07:43 AM
Sharpie14l's Avatar
Regrease the slide pins before reassembly
camarodude87
Suspension & Brakes
Mar 25, 2013 05:23 PM
Weel
Dec 19, 2009 11:25 AM
Built B18ABorC
Sep 9, 2004 07:34 AM
pbcdb
23
Mar 14, 2004 02:51 PM
