Honda CR-V & Element 2WD & 4WD Element & CR-V
New motor time
Old Jul 27, 2016 | 08:38 AM
dynamatt's Avatar
Default New motor time
ok so instead of rebuilding my top end I can get a jdm drop in motor for the same price. I've searched a ton on here but haven't come up with an answer.
I have a '98 V obviously with the b-20b, can I drop in the b-20z which had a knock sensor on the motor and run it fine without any issues?
or should I go with the b-20b with p8r head on it?
i appreciate any opinions or help on this topic
Old Aug 5, 2016 | 08:46 PM
RS Design's Avatar
Default Re: New motor time
yes you can run the b20z motor just fine, aslong as you run the same ECU that your car came with, P8R head doesnt do much havent really seen any dyno graph difference unless you start to cam the motor
Old Aug 7, 2016 | 07:49 PM
dynamatt's Avatar
This is the info on the website of the company I'm getting the motor from, I'm curious if the power number are correct
Old Aug 7, 2016 | 11:33 PM
RS Design's Avatar
they are prolly very close to what they are , but to be honest in such a moderate heavy car, you noticed the tq value is pretty much the same. Im sure the tq band is prolly similar. is you crv auto or manual? reason i ask the sweet spot of the tq band on the motor is 4k-6k its where the tq comes in peak and flat , if your car is a manual you can do a vtec head which would net you much better power band on top where the b20 falls off. only reason i ask if its a manual its a little bit easier to convert to vtec but im sure there is a way weith an automatic other then just using a vtec controller which wont have fuel and timing maps
Old Aug 13, 2016 | 08:32 AM
Johnnyrox's Avatar
I have a 98 CRV and did the swap from the b20b to the b20z. I used a 2001 north american engine and used the b20z ecu with the 98 wiring harness and ran an extra wire from the knock sensor to the ecu and everything is running fine. There have been many folks who have done what you are doing so a little more searching and you can probably find a step by step procedure. its a pretty easy swap the hardest part is getting the car high enough and stable to drop the motor and tranny from the bottom, I highly recommend using a hoist.
Old Sep 10, 2016 | 12:56 PM
dynamatt's Avatar
OK, so i ended up with the P8R engine and its in the car. The only issue i'm having is the anchor mount on the drivers side.... The mount on the block of the new motor is about 1 1/4" taller than the mount on my OG motor. Is this the difference of AT vs MT mounts? Any help would be greatly appreciated
Old Sep 10, 2016 | 01:18 PM
eh2_Trav's Avatar
Just use to mounting post from your old b20. Also the JDM engine doesn't have the CFK sensor on the oil pump like the USDM one does. not sure if that was mentioned in above post's. you have to either bypass the CFK sensor or used your old oil pump. Not doing one or the other your car will not start up.
Old Sep 10, 2016 | 01:20 PM
eh2_Trav's Avatar
Only on the passenger side if I remember correctly
Old Sep 10, 2016 | 02:08 PM
dynamatt's Avatar
We swapped the oil pump from the old B20, I'm going to swap the mount on the block.
Old Sep 12, 2016 | 10:19 AM
dynamatt's Avatar
Drove it to work today. Was running GREAT, nice to have some power back. About 10 miles into my daily commute it's starts flashing D4 but it's still doing fine on power. I get off the freeway at my exit and I realize it's not downshifting, so I manually downshift it to D3, 2, 1, and its clunking into the gears. Take off again and it's clunking up into the gears. Feels like the tranny is slipping a bit as well. I checked the lockout solenoid and it checks out fine on the ohm meter
. Starting to feel a little hopeless about this daily project
Old Sep 12, 2016 | 09:15 PM
tony_2018's Avatar
Fish Twig
When you swapped the engine did you leave the transmission in the car? You could be low on transmission fluid.
Old Sep 13, 2016 | 08:09 AM
dynamatt's Avatar
No I pulled tranny along with it. And also replaced the tranny fluid upon reinstallation of the motor/ trans. If I shift it manually 1,2,d3,d4 it drives fine. But if I just put it in d4 it doesn't shift at all. Like it's just 4th gear.
Old Sep 14, 2016 | 07:57 AM
dynamatt's Avatar
Turns out it was the VSS fuse. Put the car in limp mode. That was a very nice and easy fix
GoldLudeRay
Apr 26, 2010 04:17 AM
lsrcrvtec
Apr 8, 2007 07:01 PM
eRACING
Feb 5, 2004 05:07 PM
jansenrw
Jun 22, 2003 04:40 AM
