Jim Sir CEL
Old Jul 25, 2016 | 05:46 PM
whited's Avatar
CRX God
Default Jim Sir CEL
I was going to a car show taking the Sir with me. The bay had plenty of dust in it from sitting, so I washed it out. Some water somehow got down the spark plug tunes causing a misfire. I put new plugs and wires on, now the car is running fine. But now the cel? (probably not the cel, but what is it) is on and won't reset even with disconnecting the battery. Car runs fine. What do you guys think?
whited's Avatar
CRX God
Default Re: Jim Sir CEL
Stupid autocorrect. Jdm not Jim lol
Old Jul 25, 2016 | 05:58 PM
whited's Avatar
CRX God
I'm guessing water got in the temp sensor as well. And it is a overheating light.
Old Jul 26, 2016 | 06:37 AM
24TEN's Avatar
PHANTOM MENACE
Are you running a pre-OBD ECU setup still?
Old Jul 26, 2016 | 07:02 AM
whited's Avatar
CRX God
Its a stock SiR as far as I know.
Old Jul 26, 2016 | 09:49 AM
4drEF's Avatar
Keyboard Humorist
To get the water out, you can open up your connectors and flush them out with a can of brake cleaner and then compressed air (or just let them air dry).
When you go to put the connector back together, it's a good idea to get some silicone dielectric grease and add it to the connector body before putting it back together.
The rubber seals in the connectors go bad over time so the grease will help refresh those aged connectors.
Old Jul 26, 2016 | 12:36 PM
24TEN's Avatar
PHANTOM MENACE
If you want to verify if that is a CEL you can take a peek at the ECU and see if the LED is flashing. I've seen some indicator lights are slightly different depending on the trim/market/etc so that might be the check engine light with a different icon than we're used to. I tried to look on google briefly but didn't find anything right away.
EDIT:
Check these 2 links:
https://honda-tech.com/forums/acura-...light-2563449/
http://www.pakwheels.com/forums/mech...g-light-symbol
Old Jul 26, 2016 | 12:40 PM
whited's Avatar
CRX God
Look at the upper left corner where the left turn single is; that looks like the CEL to me, but hell if I know. Even if I did have a manual it would be in japanese.
Old Jul 26, 2016 | 12:57 PM
24TEN's Avatar
PHANTOM MENACE
Check links above, I might have updated my post at the same time you were posting.
Old Jul 27, 2016 | 06:55 AM
whited's Avatar
CRX God
Wow; This is going to be a pain to fix then.
(For future references; Image is a catalytic heat sensor that isn't an american thing maybe who the hell knows.)
lxdriver
Apr 2, 2014 09:27 PM
nizubster
Jul 12, 2013 07:33 PM
heyitsaej8
10
Dec 19, 2009 10:04 PM
Kronn 98SH
Jul 31, 2008 09:08 PM
gary201147
Dec 29, 2003 09:18 AM
