NJ 4/S 1998 Acura integra type r
Old Jul 24, 2016 | 12:13 PM
zicopenico's Avatar
Default NJ 4/S 1998 Acura integra type r
Number 367 or 398 produced in 1998
-All numbers matching power train and body with the exception of the jdm front end conversion.
-Car was never in an accident, clean carfax history, no thefts or any shady ****. Clean Title.
-280k miles on the chassis. Completely rebuilt engine along with all other general maintenance.
-There's 110 miles on the setup. No smoke or leaks.
-Body has a few dings, nothing major. All sheet metal is there and not a bondo box or a rust bucket. Interior is also not perfect but damn near, considering its 18yrs old...
-Car has no secrets, everything works.
-currently the transmission is in need of a main shaft bearing. Trans runs fine and shifts fine. Only thing is that u get that main shaft bearing noise. I have a full OEM Trans Overhaul kit with synchro tech carbon lined synchros to be installed. I haven't gotten around to it yet but if I do it before the car sells the price of the car will reflect the cost of the labor to install it. As it stands, I will sell the car with the Trans rebuild kit in the box for buyer to do.
-ENGINE-
-deglazed cylinders
-balanced and mic'd crank
-ACL race bearings (main, rod, thrust)
-mahle piston rings
-new oem oil pump
-all new gaskets and seals (ALL)
-ferrea valves
-3 angle valve seat
-new water pump, mugen thermostat, timing belt, ngk plugs, ngk wires, distributor, I'm forgetting some stuff but u get the idea...
-jdm itr header
-like new oem exhaust
-mugen air box with Samco inlet ($1020)
-Ac, heat, ps, abs, all works.
-deleted cruise control but can be easily reinstalled.
-CHASSIS-
-new brake master cylinder
-new front calipers
-steel braided brake lines
-centric slotted/drilled rotors
-power stop ceramic pads
-16" jdm oem itr wheels
-new federal 595 evo tires
-function and form suspension
-both new axles. Not rebuilds
-jdm front end conversion (HID)
-rear gurney winglet
-interior is all stock except for the radio. Still has production plate on the elbow rest. Some signs of wear on the driver seat.
-I also have a nice set of usdm gunmetal itr wheels with like new tires that I can include with the car for extra$.
Text me at 908-372-8068 for any other pics or info. PRICE $12,000
Asmar
Sep 16, 2016 08:15 AM
zicopenico
Aug 2, 2016 02:24 PM
josemig007
Jun 16, 2014 01:00 PM
dc2low
Apr 12, 2013 08:51 PM
dc2low
Apr 12, 2013 08:50 PM
