2002 Accord clutch soft
Clutch is very soft, goes right to the floor and won't go into gear. Check for leak from master and slave cylinders and couldn't find any. When car was jacked off floor we could get it into gear but when put down wouldn't go into gear. The engine wants to stall while trying to get it into gear as well.
We haven't bled the clutch but there is no pressure at all in the clutch pedal. I can push the pedal in and it stays there until I put my foot under it to pull it back up. Should I bleed the master cylinder or the slave cylinder or both?
The system is closed until you either open it, it springs a leak, or the master cylinder or slave gives out. First make sure there are no leaks anywhere. If no leaks then replace the mc and the slave and obviously bleed it.
lo0nY
Feb 26, 2006 03:58 PM
johnqt3
Oct 7, 2005 11:05 AM
Lei Siew Long
Oct 22, 2002 10:43 AM
