GA 1999 civic ex 4dr show car
Up for sale is my 1999 civic 4dr ex car. mostly original paint, never been wrecked, all original sheet metal. 503hp 322tq 16psi on e85.
$17000 obo
Exterior:
Jblood 1 piece front bumper
Top1 full underbody splitter kit
Top1 race canards
Aero catch lockable hood pins
Oem honda vi-rs rear lip
Ctr head lights
Ctr side markers
Tinted windows
Interior:
Dc5 blue record seats
Takata 3" drift harnesses
s2k cluster swap w/ktuned converter
Personel steering wheel
Nrg slim quick release carbon
Asr billet hub
the rest of the interior is mint
Engine:
B18C1 block
Eagle crank knife edged
Eagle rods with upgraded bolts
CP 10.1:1 comp pistons w/gold coating
Billet main girdle
Ported honda oil pump
Oem honda main and rod bearings
Moroso oil steel oil pan
Balanced rotating assembly
Around head studs
JE pro seal head gasket
Oem honda cam seals,crank seal, wp
Gates racing tbelt
fluidamper crank pulley
B16 head Ported and polished
Supertech valves and ti retainers
Rocket motorsports custom turbo cams
Rocket motorsports valve Springs
Locash cnc billet valve cover
Locash cnc cop plate
Aem ems
Aem epm
Downstar complete engine bolt kit
All-in fab intake manifold
All-in fab swirl pot
All-in fab coolant over flow
All-in fab tucked ic/rad combo
All-in fab murder kit (discontinued)
S90 74mm tb
DPI 2200cc injectors
Aem 3.5 bar map sensor
-16an radiator hoses
Sheepey built top Mount turbo manifold
Sheepey built 3" dp
Compturbo ct4 bb 5858 Ported housing
Tial 44mm wg
Tial 50mm q bov
Asp catch can 4 -10an vents and battery
Arp exhaust studs and nuts
The engine block is painted gunmetal
All the engine brackets powder coated gm
Innovate billet mounts
Transmission:
Mint b16 1-4th ls 5th
New bearings and seals
Carbon fiber syncros
Quaife LSD
Comp stage 5 clutch
Comp flywheel
Arp flywheel bolts
Arp pressure plate bolts
Insane shafts 500hp axles
Trans is powder coated gun metal
Downstar complete trans bolt kit
Suspension:
Koni yellow shocks
Ground control coilovers
Mpc top hats
Mpc strut top braces
Skunk2 pro front camber kit
Manual steering rack conversion
Buddy club extended ball joints
PW jdm spherical rear camber kit
PW jdm spherical rear toe adjusters
PW jdm spherical rear trailing arm bushings
Function billet rear control arms
Asr lower brace
Ctr rear sway bar
Subframe is powder coated gun metal
all the suspension powder coated gm
Arp wheel studs all around
Downstar spike lug nuts (discontinued)
Downstar complete suspension bolt kit
Brakes:
Wilwood 4 piston calipers
Rear si disc brake conversion
Crossed drilled rotors
Finishing lines full ss tucked brake lines
17" le37 wheels
IG Boostfed7
$17000 obo
Exterior:
Top1 race canards
Ctr head lights
Ctr side markers
Tinted windows
Interior:
Asr billet hub
Engine:
B18C1 block
Billet main girdle
Around head studs
Gates racing tbelt
Aem ems
Aem epm
S90 74mm tb
Sheepey built 3" dp
Tial 44mm wg
Tial 50mm q bov
Transmission:
Quaife LSD
Comp stage 5 clutch
Comp flywheel
Arp flywheel bolts
Suspension:
Koni yellow shocks
Mpc top hats
Asr lower brace
Ctr rear sway bar
Brakes:
17" le37 wheels
IG Boostfed7
I may consider parting the car out. as much as I hate to do it. all the parts have less than 4000 miles on them since the build was complete.
