A6 to Z6 Swap; Vtec doesnt engage and car bogs when warm - Lemons Race Tmr Pls Help!!
Old Jul 21, 2016 | 08:00 AM
derek358's Avatar
Default A6 to Z6 Swap; Vtec doesnt engage and car bogs when warm - Lemons Race Tmr Pls Help!!
We have a lemons race this weekend and finished swapping over a z6 head onto our otherwise stock d16a6.
-92 Z6 Head swap
-RPM activated RPM controller wired to give + input to solenoid at 5000 RPMs
PROBLEMS >>>
-When the car is cold it idles and revs fine with excellent throttle response
-When the car is operating temp. it idles fine but throttle response is very poor in low RPMs
-At all times once the vtec controller activates our solenoid, the car bogs and RPMs drop below activation and shoot back to 5K activates and bogs (constant cycle)
So my question are for this race that we have this weekend.
-Can i run the car without vTec? I assume yes
-what would cause such a throtle response issue when the car is at operating temp
Any and all help is appreciated; we just want to go out and race!!
Old Jul 21, 2016 | 08:42 AM
derek358's Avatar
Default Re: A6 to Z6 Swap; Vtec doesnt engage and car bogs when warm - Lemons Race Tmr Pls He
pics for attention lol
Old Jul 21, 2016 | 09:10 AM
24TEN's Avatar
PHANTOM MENACE
If it's running on the original ECU still that's probably the issue. It may have a difficult time adjusting A/F to an appropriate level for the non/VTEC and VTEC lobes, maybe it's completely out of it's operable compensation for the VTEC lobe and that's why it's doing that. Realistically, maybe it's your best bet to run it without VTEC since the race is tomorrow. I'd double check mechanical timing as well as ignition timing, adjust ignition timing to see if you can get it to run better/smoother. If not, I'd skip activating VTEC. Longevity seems to be the goal of these races anyway. Good luck!!
Old Jul 21, 2016 | 09:20 AM
derek358's Avatar
foregoing vtec activation as long as our motor would run properly would be fine by me..
were looking at an 18hr race over 2 days.. longevity is key lol!
what i dont understand is why a good handful of the swaps utilize the pm6 ecu with rpm controller? do i need to use the FPR off the Z6 head? i swapped to my a6 fpr cause the fuel line in was much larger
Old Jul 21, 2016 | 01:39 PM
fcm's Avatar
fcm
Old Fart
Seems fine when engine cold but not once warmed up?
Have you checked the ECT sensor? 94
Old Jul 21, 2016 | 03:47 PM
4drEF's Avatar
Keyboard Humorist
The old school way to use the RPM activation along with an A6 ECU was to also use an adjustable FPR.
Far from perfect, but it would somewhat compensate for the additional fuel required when vtec engaged.
slow93eg
Sep 21, 2006 04:13 AM
JDM_EK_JOE
Apr 27, 2006 07:38 PM
TallKyle
47
Feb 11, 2005 08:34 AM
TallKyle
Feb 1, 2005 08:25 AM
Go Fast Civic
Nov 21, 2004 09:22 PM
