95 del sol - headlight switch broken off
Old Jul 20, 2016 | 09:32 PM
trailblazer's Avatar
Default 95 del sol - headlight switch broken off
my 95 del sol came with the headlight switch broken off. i cleaned the terminals inside it and everything works good, i have enough of the **** to bump up and down for the signals to work and i believe it bumps out for high beams too? but the stick itself broke off so i cannot operate the twisty **** for the lights, i dont even know what that **** operates exactly, lights hi low and off?. i saw the terminals that the **** operates, by sliding them.. it still moves and works fine but since the **** broke off, can i wire a 3 way switch or somthing instead to operate what the twisty **** operates?
Old Jul 21, 2016 | 06:01 AM
Former User's Avatar
Default Re: DIY Combination Switch Fix (Headlight Switch) AND Wiper Combo Switch
Visit a junkyard or eBay to find a replacement.
Old Jul 21, 2016 | 08:57 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 95 del sol - headlight switch broken off
Soooooo... let me get this straight. You are asking this community if a bunk, ghetto-fabulous MacGyver style fix is the right thing to do ??? Since it appears that the part number is discontinued from Honda, RonJ's suggestion is likely your best course of action. It will be important to get one for the same trim level as your car... S, Si, or Si VTEC.
Put some effort into fixing it correctly and it will serve you well for many years to come.
Old Jul 21, 2016 | 09:20 AM
my car is the vtec model. i cant find the part anywhere. apparently its only made for the 93-95? already tried the junk yards and ebay..
Old Jul 21, 2016 | 09:21 AM
This is a great resource:
https://www.google.com/webhp?tab=mw&...ed=0EKkuCAQoAQ
I'll even Google it for you.
https://www.google.com/webhp?sourcei...l+light+switch
Here are some eBay search results:
http://www.ebay.com/sch/i.html?_from...witch&_sacat=0
http://www.ebay.com/sch/i.html?_odkw...witch&_sacat=0
Old Jul 21, 2016 | 09:33 AM
i dont want to have to buy the whole column again for 80.. i need brakes more then this lol. this is mine broke off.. https://imgur.com/a/wjpu5
i can glue a stick onto that so i can work my turn signals and id have to wire a switch for the headlights
edit: i want to either overide the ***** controlls or just rewire the headlights at the source *which i dont want to do*
it just seems like a waste because my switch is litterally perfect i even stuck a screw in there and that was working but it fell out
Old Jul 21, 2016 | 09:39 AM
what does the **** operate exactly does anyone know? hi low off?
Old Jul 21, 2016 | 10:02 AM
Again? Not sure what you mean.
I led you to the solution. Fix your brakes and then save up for a switch replacement. Do it right.
Old Jul 21, 2016 | 10:10 AM
well i once saw just the left side switch for sale for 20.. id hate to buy the whole 80$ set with more parts then i need, when mine is all fresh just broken off arm. i want to just rewire the twist **** so bad. i think i see what pins its activating
Old Jul 21, 2016 | 10:31 AM
Do daily Google searches just for the light switch. Do it right. If you're persistent, you'll find one.
Haha
Old Jul 21, 2016 | 10:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Why didn't you buy the one for $20 when you had the chance ???
Old Jul 22, 2016 | 05:34 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Any headlight switch will work from 1992 to 2000 Civics or 1997 to 2001 CRV. Plug and play. Stop ******* about and buy a replacement switch, there is no way to fix yours for it to work reliably. Like less than $20 at the junkyard. Thread closed because your problem has been solved.
justicap
Aug 8, 2016 03:28 PM
nintonda
Aug 10, 2008 09:43 AM
imdgoatboy
Feb 22, 2004 08:13 PM
