Honda CR-V & Element 2WD & 4WD Element & CR-V
'98 V door lock woes
Old Jul 20, 2016 | 11:38 AM
dynamatt's Avatar
Default '98 V door lock woes
I just recently picked up a 98 CRV to use as a daily driver, the power locks functioned intermittently with the switch in the drivers door so I hoped that maybe the factory keyless would offer me a better solution assuming it was a faulty switch. Well after programming the remotes that clearly wasn't the issue either. So I pull the drivers door apart and check out the module, you can hear the relay inside clicking when lock-in and unlocking but none of the doors can actually lock or unlock themselves. It almost seems like they don't get enough voltage to properly function. They move, but not full throw.
My question is this, has anyone had this specific issue with their V, and if so. Can you help a fella out with some info??
Kris's turbo
Acura TL, RL & ZDX
Feb 13, 2011 06:24 PM
dandaman15
Dec 10, 2009 05:18 PM
kornerk12
Jan 9, 2009 02:26 PM
danb18c
Jan 20, 2008 05:49 AM
MugenManR
Jan 10, 2007 02:17 PM
