Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
question about my wilwood calipers i just got today
Old Nov 7, 2002 | 08:49 PM
Hunter's Avatar
Default question about my wilwood calipers i just got today
i just got this kit in from fastbrakes.com. it came w/ wilwood 4 piston calipers. it's a very sweet kit, but why the heck has the caliper on the left been grinded down? it doesn't look like it's been mounted on a car before, but it just looks older than the one on the right. any thoughts or ideas?
[Modified by Hunter, 12:51 AM 11/8/2002]
Old Nov 7, 2002 | 09:46 PM
Tomakit's Avatar
Default Re: question about my wilwood calipers i just got today (Hunter)
To possibly clear 15" wheels? Last set I worked on were ground down also but req'd 16" wheels to fit under.
Tom
Old Nov 7, 2002 | 09:49 PM
GSRrR's Avatar
Default Re: question about my wilwood calipers i just got today (Tomakit)
That set is defective, please send them to me right away.
Which fastbrakes kit is that? Fit under 16in rota c8s?
Old Nov 7, 2002 | 09:57 PM
PyroVTEC's Avatar
New User
Default Re: question about my wilwood calipers i just got today (GSRrR)
Man you got the nice billet ones, eh?
My cast Superlite IIA calipers I got from Brian were slightly ground too--I had him grind it down in parts where it might meet the back of the 15" GSR wheel I had been using. He also uses them to test fit some of his latest rotor combos too. I still think he oughta disclose the fact that he's used that caliper to test them though.
Old Nov 7, 2002 | 10:03 PM
Trickturn's Avatar
My Wilwood calipers came fine. You need to talk to Brian about those. Only he can clear things up w/ you.
Pete
Old Nov 8, 2002 | 01:41 AM
Rob Dizzle's Avatar
Default Re: question about my wilwood calipers i just got today (pest)
Pete
most likely adapted to fit on the brackets
or shaved a bit to fit under your wheel
im sure for a good reason either way
Old Nov 8, 2002 | 06:19 AM
Hunter's Avatar
Default Re: question about my wilwood calipers i just got today (Bob-DC2)
it's the 11" rotor w/ 4 piston wilwood caliper set. it will fit under most 15" wheels.
Old Nov 8, 2002 | 06:27 AM
ILUVTEC's Avatar
Yeah, he more than likely grinded them down for fitment reasons, therefore you may have to do the same to the other one, atleast now you know how much, so it may actually be beneficial that he included one that is already done, just ask him, he is a good guy and I am sure that he will clear it up, later
Old Nov 8, 2002 | 05:46 PM
electronspeeder's Avatar
Default Re: question about my wilwood calipers i just got today (ILUVTEC)
Any update?
Old Nov 8, 2002 | 06:15 PM
Hunter's Avatar
Default Re: question about my wilwood calipers i just got today (electronspeeder)
not yet, still waitin' to hear back from brian. i'm sure it's all good and he'll clear it up, he's a good guy
Old Nov 9, 2002 | 10:11 AM
743power's Avatar
I have those calipers and I need to change my pads real soon. Is there an OEM pad with the same dimensions, or do I have to call fastbrakes or wilwood to get replacements?
Old Nov 9, 2002 | 12:17 PM
chad's Avatar
Moderator
Default Re: question about my wilwood calipers i just got today (743)
get HAWK BLACKS.....great for the street and only bout 40 bucks for the pair (both sides)
Old Nov 9, 2002 | 12:49 PM
89civicdx's Avatar
Default Re: question about my wilwood calipers i just got today (Chad)
Are pads cheaper for these willwood calipers than for stock calipers?
Old Nov 9, 2002 | 01:40 PM
PyroVTEC's Avatar
New User
You can get pads from Wilwood, Porterfield, Hawk... or any large brake pad manufacturer. They are much larger than the OEM Honda brake pads. From what I recall, I think the pads for the Wilwood Superlite IIA are quite cheap as the caliper is very popular in the aftermarket as far as brake calipers go. For me, I've been reasonably satisfied with the Wilwood Type D pads (although they're gone after 10K miles), although my next set will be the Porterfield R4S for my FB/Wilwood Superlite IIA calipers.
Anyone put in the proportional brake balance valve yet? These Wilwoods have shifted the braking bias a little more to the front...
Old Nov 9, 2002 | 03:59 PM
Driven's Avatar
Default Re: question about my wilwood calipers i just got today (PyroVTEC)
a little more? HA!
Old Nov 9, 2002 | 05:11 PM
89civicdx's Avatar
Default Re: question about my wilwood calipers i just got today (Driven)
Sorry to go OT but could someone tell me the price for hawk blues for the calipers with the fastbrakes kit.
Thanks
Old Nov 10, 2002 | 12:37 AM
PyroVTEC's Avatar
New User
a little more? HA!
Heheheh... okok! A lot! I just keep telling myself it's not that bad... really!
Someone has got to have done the prop valve though! Anyone? Bueller??
Old Nov 10, 2002 | 05:45 AM
DTAYLOR's Avatar
New User
I have the 11 front with the wilwood cal and I just got race rear pads it will make the braking bias real close to what you would like.
Old Nov 10, 2002 | 10:35 PM
PyroVTEC's Avatar
New User
Default Re: question about my wilwood calipers i just got today (DTAYLOR)
Define race rear pads. What pads are you using?
Old Nov 11, 2002 | 03:28 AM
DTAYLOR's Avatar
New User
Iuse the R4 race pads but I have been thinking about using KFP ones. I was told that they make the pads for Portfield,And they also have a pad for the rear that has a higher Cf for more brake bias.
Old Nov 11, 2002 | 08:38 AM
Rob Dizzle's Avatar
did you figure out what the deal-e-o is?
Old Nov 11, 2002 | 08:40 AM
robbin's Avatar
What about temps. Do they still work when cold. It seems to me it might be hard to get a race pad up to temp on the rears.
Old Nov 11, 2002 | 09:19 AM
DTAYLOR's Avatar
New User
Default Re: question about my wilwood calipers i just got today (robbin)
I do not know about temps BUT there is a very big difference with or without the race pads. I would not use Hawk Blues in the back but other pads work very good back there. The R4 and the R4S pads work well on the street or track. I would first try the R4S and if you would like a little more rear brake get the R4 race pads. Also I have this set up on my Crx with a LS-vtec swap. Short wheel base and a little more weight up front then stock.
Old Nov 11, 2002 | 10:45 AM
Hunter's Avatar
Hunter,
Both calipers are new, I just used them for test fitting purposes. The one has a little material taken off the underside as I was testing a new rotor hat. One has the silver spacer and one the black cause they started plating the spacers...both will work just fine. Sorry about that I should have told you...
everything's been cleared up. it's all good! for fastbrakes
philcivicjordan
Suspension & Brakes
21
May 13, 2018 01:16 AM
vteclolz
Jul 24, 2012 03:01 PM
vietxdragon
Suspension & Brakes
Oct 6, 2008 09:26 PM
Chef Andre
Suspension & Brakes
Jun 29, 2008 07:34 PM
Dorikamu
12
Apr 26, 2002 04:55 PM
