Air in clutch line (wont go into gear)
Old Jul 19, 2016 | 04:45 PM
Lareau's Avatar
Default Air in clutch line (wont go into gear)
So yesterday my car wouldn't go into gear when I pushed the clutch in all the way. So I checked the fluid and it was really low. Today I went and got a bleeder kit and clutch fluid. While I was bleeding the system bubbles were constantly coming out. The old fluid was black and I flushed it out til it was clear. Afterwards the clutch was still doing the same thing. I looked for leaks in the line and inside the cab and everything was dry. I was wondering if I could blow air in the bleeder valve and see if any leaks show that way or is that a bad idea?
Old Jul 20, 2016 | 03:26 AM
tony_2018's Avatar
Fish Twig
Default Re: Air in clutch line (wont go into gear)
did you have someone inside your car stepping on the clutch pedal while you look at the fork?
Old Jul 20, 2016 | 05:56 AM
mk378's Avatar
Look for leakage out of the slave cylinder (pull the boot off). The fluid must have gone somewhere.
Like Tony said, you should try conventional bleeding with someone in the car pushing the pedal.
Old Jul 20, 2016 | 06:58 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Do a one-person bottle bleed till you are 100% confident all the air is gone.
Check all the components for leaks.
If it all checks out...you may need a freeplay adjustment on the pedal and/or a new clutch or clutch component(s).
motrayEG6
Mar 16, 2010 10:02 PM
deklao
Jan 22, 2008 11:56 AM
JDMgareth
Jan 21, 2008 03:36 PM
stealth89hatch
16
Feb 18, 2005 10:53 PM
Whig-it
Jun 21, 2004 06:21 PM
