Fs: gt3040r garrett turbo $550,and other turbo parts
have a very very low mile center section gt3040r turbo The shodan said this would be a good 500whp area turbo. its a t3 housing .63 a/r hot side 5 bolt dp, 4" inlet compressor cover,2.5" outlet .70 a/r. turbo is great only selling due to getting a bigger turbo and high goals then had planned
preformer x intake for Ls/b20 $300 as well,
68mm skunk tb $120 with sensores,
venom gsr intake $120
will post pics tomarrow evening thanks for looking.
Here are the adiabatic compressor airflow map and turbine gas flow maps for the GT3040R in case there are those curious about this turbo.
Please note: For the record, I have no affiliation with neither the seller nor the item being sold itself. I am simply being courteous and adding information for anyone curious about the makings of the GT3040R.
Please contact the original seller of this item to get further details or utility of it's condition. I will not answer questions regarding whether or not this turbocharger is "right" for your build or application.
Compressor map
Turbine Gas Flow Map
Measurements:
Compressor:
61.4mm inducer
82mm Exducer
56 trim cast wheel
Turbine: (Same used in the GTX3071R, GTX3076R, GT3076R,)
60mm inducer (wheel diameter)
54mm exducer
84 trim
Compressor map
Measurements:
Compressor:
61.4mm inducer
82mm Exducer
56 trim cast wheel
54mm exducer
84 trim
I only helped the OP help explain to others what a GT3040R is, for those that do not know. I did not sell anything to this individual at any time. So, there is no exclusion of any rules being allowed here. The OP needs to properly post photos of the item on this for sale thread. The OP has one week to post pictures here, or I will recommend its closure.
