2004 Honda Accord AC/Heater No Air
Hi. I have an 04 Accord coupe. I currently have no air coming out of the vents no matter what setting or speed I have on. In the past, sometimes the air would turn right on and be fine an other time it would take a few minutes to come on and now won't come on at all. I've checked the fuses and all look well. I ordered a blower motor resistor but that didn't fix the issue. I am about to order a blower motor. Is there anything else I can check before I order the motor? Thanks.
1. Locate the blower power transistor under the passenger dash.
2. Unplug the electrical connector to the transistor unit.
3. Attach a jumper wire (short piece of wire) from the Blue/Black wire cavity to the Black wire cavity on the unplugged electrical connector. Leave the connector unplugged.
4. Turn the ignition ON, does the motor run?
maysx3
May 31, 2017 02:37 AM
ddeem1
Jul 22, 2014 05:51 AM
