92 Civic DX Cranks but won't start
Old Jul 17, 2016 | 12:02 PM
Redder's Avatar
Default 92 Civic DX Cranks but won't start
I have a 1992 Civic DX that cranks over but won't start.
I am getting spark from the distributor coil but not from the plugs. I am not getting fuel and I do not hear the pump priming when I turn the Ignition into the ON position.
I tried shorting the #1 and #7 terminals on the fuel pump relay but did not hear the fuel pump prime. I tried shorting the #5 and #7 terminals and it did prime.
I tried cleaning and tightening G101 ground wire attached to the thermostat housing and I finally got it started. I let it run from a minute and shut it off. And now I cannot get it to start again.
I have tried cleaning the ground wire again and again but I cannot replicate what got it to start that one time.
Grateful for any advise.
Old Jul 17, 2016 | 12:51 PM
Former User's Avatar
Default Re: 92 Civic DX Cranks but won't start
Sounds like fuse 31 is blown under the hood.
Old Jul 17, 2016 | 01:17 PM
Redder's Avatar
No. Its getting power.
Old Jul 17, 2016 | 01:18 PM
What's getting power? Please provide unambiguous responses.
Old Jul 17, 2016 | 01:20 PM
Redder's Avatar
Fuse 31 under the hood is getting power. I checked it with a test light by grounding the test light to the negative terminal on the battery and touching both metal receivers on top of the fuse.
Old Jul 17, 2016 | 01:21 PM
Are you saying both top test tabs of fuse 31 have battery voltage?
Please post a picture showing what you think is 15A hood fuse #31.
Old Jul 17, 2016 | 01:23 PM
Redder's Avatar
Yes both top test tabs have battery voltage.
I can't take a picture. Sorry.
Old Jul 17, 2016 | 01:26 PM
Convince me you're testing the correct fuse (#31).
Draw a picture? Describe location in text? Post somebody else's picture of the same fuse box?
Old Jul 17, 2016 | 01:28 PM
Redder's Avatar
Its in the top left corner of the underhood fuse box.
Old Jul 17, 2016 | 01:32 PM
Excellent.
With the key off, do you detect voltage at pin 1 of the unplugged main relay connector?
Old Jul 17, 2016 | 01:36 PM
Redder's Avatar
Yes. I am getting voltage.
I used my test light by grounding it to a bolt on the door.
Old Jul 17, 2016 | 01:39 PM
Are you now as puzzled as I am that this^ 1-7 jump test did not make the fuel pump run whereas the 5-7 jump test did?
Redo the two jump tests.
Refer to the diagram I posted for the correct main relay connector pin numbers.
Old Jul 17, 2016 | 01:41 PM
Redder's Avatar
That's right. 1-7 got me nothing. 5-7 and the fuel pump primed. I was using a paper clip. not sure if that is a good idea.
Are you not puzzled by your results too?
Old Jul 17, 2016 | 01:47 PM
Redder's Avatar
guess i was doing it wrong the first time. Now I hear the fuel pump prime on 1-7.
Old Jul 17, 2016 | 01:48 PM
Redder's Avatar
and yes. I have been puzzled for weeks.
Old Jul 17, 2016 | 01:49 PM
Did you verify hearing the pump prime with the 5-7 jump test?
Old Jul 17, 2016 | 01:51 PM
Redder's Avatar
jumping 5 to 7 also makes the fuel pump prime.
Old Jul 17, 2016 | 01:52 PM
I was asking a logic question.
You originally said that 5-7 made the pump run but not 1-7.
However, you now said that 1 has voltage, which questioned whether you did the 1-7 test incorrectly.
Old Jul 17, 2016 | 01:53 PM
Plug the main relay connector back in.
Turn key to ON(II).
Does the CEL turn on for 2 seconds and then turn off? Does the fuel pump run for 2 seconds and then turn off?
Old Jul 17, 2016 | 01:56 PM
Redder's Avatar
I must have performed the diagnostic incorrectly when I first did it. But now I feel confident that I am doing it right. When I jump terminal 1 to terminal 7 I hear the fuel pump prime. When I jump terminal 5 to terminal 7 I also hear the fuel pump prime.
Old Jul 17, 2016 | 01:57 PM
Turn key to ON(II).
Old Jul 17, 2016 | 02:00 PM
Redder's Avatar
I turned the key ON(II) and the Check Engine Light goes on and stays on. Nothing from the fuel pump.
Old Jul 17, 2016 | 02:03 PM
Plug the main relay connector into the main relay, if unplugged.
Turn key OFF.
Unplug ECU connector A.
Turn key to ON(II).
Use a jumper wire to ground the Grn/Yel wire at pin A7 in ECU connector A to the metal frame under the dash.
Does the fuel pump run as long as pin A7 is grounded?
Old Jul 17, 2016 | 02:14 PM
Redder's Avatar
This might be a stupid question but is there anything I can use instead of a jumper wire? I don't have one on hand.
