Help ignition timing
Old Jul 14, 2016 | 04:10 PM
Blueman5624's Avatar
Default Help ignition timing
Hi guys I'm new to here I usually don't have any issues with rebuilding motor and stuff but I'm stuck on a 90 Honda Civic ex has a d16a6 block and a d15b1 head I think the cam hear says pm3 idk but anyways I got the timing on the marks but when I go to adjust the ignition timing the marks are a inch- a half inch off to the right if your in front of the pully firewall side. I can't seem to set it right it fires up great and runs with a little of mis Fire but not noticeable. I need to tips on getting the marks to line up so I can finish the job. Thanks the front of the head says pm9-3 also thanks of Somone can help me out would be much appricated
Old Jul 14, 2016 | 04:13 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Help ignition timing
You have to disable the electronic ignition advance while setting timing.
This is done by putting a jumper in the connector that you use to retrieve trouble codes.
Old Jul 14, 2016 | 04:52 PM
I have done that. also messed with the dizzy and still nothing
Old Jul 15, 2016 | 05:48 AM
jlicrx's Avatar
sounds to me like the camshaft timing is off - did you use the single mark to the right of the three ignition timing marks for TDC?
Old Jul 15, 2016 | 08:31 AM
Yes I did. I set the cam to the mark on the head and the crank to white dot tdc mark the one by its self.
Old Jul 15, 2016 | 08:32 AM
The front of the head says pm9-3 and the cam hear says pm3 so idk if I have the a6 head on there
80strucksrule7
Jul 31, 2012 02:58 PM
jdmasfuk
Jul 15, 2010 07:06 AM
eg grom
Jun 25, 2009 09:27 PM
maxmax
May 14, 2006 03:37 PM
