Shock absorber
They don't have service intervals, you just replace them when they go bad. The easiest way is the bounce test. With the car parked on flat ground, use body weight to get one corner bouncing up and down, and then let go. It shouldn't take more than 1 rebound to stop moving. If it does, that corner has failed. You can also look at the shock to see if it is leaking.
There's also this. Borrowed from a Toyota forum, but still applies.
navcc
Apr 10, 2011 12:42 AM
chrisff521
Suspension & Brakes
15
Oct 27, 2009 07:19 AM
tylerdurden
Oct 22, 2003 06:02 PM
