Transmission & Drivetrain Gearboxes, Differentials, Clutches
Upgrading tranny, 4.7 or 4.4 LSD
Old Jul 13, 2016 | 01:49 AM
DeFinitive's Avatar
Default Upgrading tranny, 4.7 or 4.4 LSD
I'm getting my 2000 EK SiR track ready and one "must do" job is the tranny due to 2nd & 3rd gear damaged gear sets in the current b16a with stock tranny.
Had my mind set on a S80 4.7fd LSD but getting mixed opinions, I thought that would be perfect for our local circuit.
Been looking at a few of the older tranny threads but would just like some newer opinions if the 4.7 LSD is the way to go or would 4.4 LSD be enough? I have looked at a few charts with the gear ratios, would also do a bit of daily driving with it.
Another option is changing out the 2nd & 3rd gear sets and replacing current non LSD FD with one of the LSD types but not so easy to get the individual parts here, everyone selling complete type r tranny's.
Old Jul 13, 2016 | 07:58 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Upgrading tranny, 4.7 or 4.4 LSD
I loved my 4.78FD. The motor attached to it was a B18C-R. It was in a DC2 ITR. It helped to keep the car in 3rd on corners where I'd debate slowing down more to put it in 2nd to get more exit acceleration...or bogging midcorner to keep it in 3rd.
The shorter 4.78 FD just allowed me to keep it in 3rd.
Obviously, results will vary depending on what the circuit layout is. I'm sure there are tracks that favor a 4.4FD.
But the 4.78 did improve the street driving experience as well. The car felt more torquey and the gear reduction was not overkill.
I had a N3E trans that has the GSR 4th and 5th. I would NOT recommend the GSR 4th. I would only partially endorse the GSR 5th...but will say its unnecessary. I would ideally have a B16/USDM ITR/96-97 JDM ITR 4th and 5th...even with the 4.78.
IDGAF about the increased revs on the highway....and neither should you.
4.78 gets my
Old Jul 13, 2016 | 05:24 PM
DeFinitive's Avatar
4.78 gets my
Thanks for the input, cheers!
Old Jul 13, 2016 | 05:37 PM
testify's Avatar
On vacation
I love my S4C Type R trans with the 4.4
Old Jul 13, 2016 | 06:44 PM
DeFinitive's Avatar
I'm talking with someone now about a S4C, think this is what I'll end up with, it's only 10mins away from where I'm at and it's much cheaper than the S80 4.7.
Is the S4C just a straight swap, what are the issues with it being hydraulic if any?
Old Jul 13, 2016 | 06:50 PM
testify's Avatar
On vacation
I'm not sure what you mean by 'hydraulic issues'.
It has a proper helical diff, dual carbon synchro on 2nd, 3rd, and 4th, and nevet misses a beat.
It's about as proper a road race transmission as you can get from the factory.
Old Jul 13, 2016 | 07:23 PM
DeFinitive's Avatar
I'm not sure either lol, just saw in a Honda engine swap thread where they quote "it's also worth mentioning that these transmissions are hydraulic type".
I'm looking forward to see how it performs on the circuit, everyone says the LSD is game changing for circuit racing.
Old Jul 13, 2016 | 07:27 PM
testify's Avatar
On vacation
It just means the clutch is actuated by hydraulics instead of a cable.
Older cars, built before 1992 used cable transmissions.
You'd not be happy if you bought a cable transmission for your application.
Old Jul 13, 2016 | 07:42 PM
DeFinitive's Avatar
Haha I guess not. It's a Japan surplus so should be good
Old Jul 14, 2016 | 01:29 AM
DeFinitive's Avatar
Anyone know how I can make sure it's a S4C and not a Y21, what's the difference anyway as they both have same gear ratios?
Old Jul 14, 2016 | 03:05 AM
B serious's Avatar
Buy it from a reputable place. You'd need to make sure that your S4C LSD trans is from a CTR and not a Si/Si-R. The CTR has the fancy synchros and helical diff. The Si-R has a viscous diff, IIRC.
Yes...the LSD makes a huge difference on a track.
Old Jul 14, 2016 | 04:17 AM
DeFinitive's Avatar
Thanks B serious, the local guy that's offering the S4C has a reputation at stake, we have quite a massive EK community here and if he did wrong everyone going to know about it, I don't think he would risk that. The other guy imports locally but lives elsewhere, also a reputation to keep intact.
Their prices are a little bit apart which is making me ask a few questions of the cheaper option. Hopefully we can open it up before purchase to confirm.
Both of them buy surplus direct from Japan. I'll be inspecting it tomorrow along with my trusted mech, will let you know how it goes, hopefully along with some pics.
Appreciate the help guys, cheers!
Old Jul 14, 2016 | 10:16 PM
DeFinitive's Avatar
The trans was Y21 and had already been opened, so I'm still looking.
Old Jul 28, 2016 | 09:42 PM
DeFinitive's Avatar
I looked at another two today, the S80 had a 4.4 FD and the S4C had a 4.7 FD, seems both had been changed in Japan. Both had helical diffs. Apparently both had came out of half cut CTR's that were imported for parts out but obviously had the trannys internally changed in Japan.
The 'fancy synchros' you mention, is that dual synchros or just more robust synchros than that of standard?
Old Aug 11, 2016 | 05:08 PM
DeFinitive's Avatar
Finally got my hands on a S4C 4.4 Lsd tranny, it's installed and running good.
I've also got my hands on a type r shift linkage with an option to buy, is it worth it, will it fit and will there be a noticeable difference when shifting?
Old Aug 11, 2016 | 06:22 PM
testify's Avatar
On vacation
All b series DC integra and EG Civic linkage should be the same.
Old Aug 11, 2016 | 06:36 PM
DeFinitive's Avatar
Is it worth the upgrade to type r linkage/shifter?
Old Aug 12, 2016 | 07:42 AM
B serious's Avatar
for a 2000 civic, the integra linkage is a huge upgrade. Any DC integra is functionally the same. JDM Type R's have a zinc plated linkage and chrome shifter.
You may need to clearance the DC's link stabilizer near the catalyst. Or use an EM1 stabilizer with DC shifter rod and shifter.
Old Aug 12, 2016 | 08:07 AM
DeFinitive's Avatar
Thanks, I have already decided to go ahead with it. I've currently got a ktuned shifter on my stock linkage, that needed a little bit of clearance work to get it fitted with properly.
si90rex
Welding / Fabrication
Sep 22, 2006 09:37 AM
Fuuma0083
Jul 27, 2003 08:53 AM
