Got a oil leak.
Old Jul 12, 2016 | 04:59 PM
Rob Jess's Avatar
Default Got a oil leak.
Hey guys I have a 98 and I have a bit of a leak going on. I know where it's coming from but not exactly sure what it is that's leaking. Here is a picture of what it is coming from now please tell me what it is lol. Thank you
That's right below my oil filter. And no it's not dripping down from the filter.
Another view
Old Jul 12, 2016 | 06:04 PM
whaemmel's Avatar
Default Re: Got a oil leak.
Don't have a lude but it has to be oil sending unit(for oil light or guage). Under the rubber boot you have a wire connector. Unplug it and turn engine on to check it. common leak.
Old Jul 13, 2016 | 04:34 PM
snobordboy's Avatar
Moderator
Looks like the very common oil cooler o-ring. Pull off the filter and then you undo the shaft through the cooler. The new o-ring is a couple of bucks from Honda, and using an oem part is the best way to go.
Old Jul 13, 2016 | 05:07 PM
holmesnmanny's Avatar
It's a big bolt. It's like a 30 or 32mm.
Old Jul 13, 2016 | 05:59 PM
Rob Jess's Avatar
What? What's leaking is that thing with the boot over it and the wires coming from it. Are you saying that's an oil cooler?
Old Jul 14, 2016 | 11:32 AM
It's possible it's the oil pressure sensor leaking but if you look behind it to the bottom of the oil cooler which is behind the oil filter it seems to be leaking at the bottom.
part 32 oring, very common to have to replace this
OIL PUMP - OIL STRAINER for 1998 Honda PRELUDE
chiaxi2002
Apr 9, 2010 08:56 PM
holmesnmanny
Dec 10, 2009 03:14 AM
tdac69
Honda Civic (2001 - 2005)
Oct 28, 2007 04:15 PM
italstallion
Sep 5, 2007 12:08 PM
People_Mover
May 19, 2003 01:05 PM
