H2b ek coupe 1/4 times?
Hey guys i have a ek coupe with an h2b setup on street tires. Full weight basically. Dynoed at 211/170.
What time should i expect in the 1/4 with a decent launch?
I'm shooting for mid 13's, is this an attainable goal on street tires?
Thanks! And sorry if this question is in the wrong section.
#1 Your track conditions ie elevation, temps, prep, headwind etc
#2 seat time ie preloading, feathering clutch/gas, shifting skills etc
211 whp is plenty of power for 13s in a decent weight EK
I went 13.6@101 or so with about 165whp/2440 lbs with a full US itr swap rev limited to 8200 rpm ...on a 2.08 60 ft which isn't great
This was in the fall, at night with temps in the low 70s high 60s.
Given you'll have way more power it will be a matter of cutting good short times. But even with a 2.2 60 ft your power should realistically be able to still run mid to low 13s on streets depending on weight and track conditions. All motor setups are very sensitive to track conditions
I will say street tires are very inconsistent to launch on and have a very small window to operate in for proper launches ......slicks will solve alot of problems and make launching a snap.
In before the lock
stoppa
Apr 23, 2017 05:21 AM
