Power steering questions
Old Jul 11, 2016 | 06:22 AM
blackj30_a's Avatar
Default Power steering questions
I Have a 98 sedan V6. My power steering pump would whine every now and then because I have a leak. I would normally just put more power steering fluid in and it would stop till my fluid was low again. Well it started whining again and the power steering fluid is at a ok level. I dont know if the power steering pump finally took a dump on me as I don't see any leaks around the power steering pump BUT it does leak under the car on the side the reservoir is on. I know I need to start by finding where the leak is coming from BUT also since the reservoir is still holding more than enough fluid should i start by maybe flushing the system and if that doesn't work then just replace the pump?
Old Jul 11, 2016 | 12:50 PM
blackj30_a's Avatar
Default Re: Power steering questions
Anybody?
Old Jul 11, 2016 | 01:14 PM
user456101's Avatar
Scotty Kilmer has a couple of YouTube videos. "Fixing sticking power steering" , "Fixing noisy power steering" and "Replacing a groaning power steering pump" Those should cover what you need to know. there is also a liquid polymer called AT-205 Re-seal that can sometimes stop gasket leaks on power steering. You can get it on Amazon, but it is not in many auto parts stores.
Old Jun 2, 2022 | 05:10 PM
lookyHere's Avatar
Did you ever figure out where the leak was coming from? I have the same problem and I suspect it's the power steering pump.
Old Jun 2, 2022 | 06:16 PM
nd4sped's Avatar
Premium Member
If reservoir is hold fluid then it shouldn't have a leak unless it cracked high up. I would think your inner drivers side steering rack gasket has failed. This will require removing the entire rack from the car to tear down the rack. Its not hard to do but will give you a nice Saturday worth of work.
dcarey
Jun 10, 2017 08:17 AM
__oversea
Jul 21, 2008 05:14 PM
ibme_uk
Jan 6, 2005 08:23 AM
boostedcvc
Jan 3, 2003 09:45 AM
