Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
AC is always engaged. 2010 honda civic.
Old Jul 11, 2016 | 05:54 AM
tontontons's Avatar
Default AC is always engaged. 2010 honda civic.
So i had problems with my ac. My friend and i replaced the old compressor with a new one. Checked all the grounds and everything. Whenever i start the car. My ac clicks on and the clutch engages. And it does not stop. Any ideas why this is happening? All connections are connected properly. No leaks. I just constantly have airconditioning. Its freezing up my lines when i take long trips.
Old Jul 11, 2016 | 12:40 PM
av911's Avatar
Default Re: AC is always engaged. 2010 honda civic.
Is your defrost on/selected? I remember when you select Defrost, A/C will turn on even though the button isn't lit. There's was a hack to prevent this.
Old Jul 11, 2016 | 07:40 PM
tontontons's Avatar
No its not. I have everything off and not on the defrost mode.
When i put the car on the on position the fan in the engine starts blowing. Then when i start the car, after 5 secs the ac clutch engages without me even turning the ac on.
Old Jul 13, 2016 | 05:01 PM
holmesnmanny's Avatar
Disconnect the ac relay and see if it stops. You could then swap it with another one and see if that fixes it.
The weird thing is that the evaporator temp sensor should turn off your ac before the evap freezes so in addition to your core problem it's likely the evap temp sensor is bad and this occurrs so much that it's clear that the evap temp sensor on our gen is absolutely atrocious.
Old Jul 14, 2016 | 03:39 AM
tontontons's Avatar
I tried switching relays. Still the same problem. My next step is switching the hvac controller. If that doesnt help. Ill check that evaporator temp sensor.
Old Jul 14, 2016 | 01:18 PM
You need to get your hands on a shop manual and go through the troubleshooting flow charts. They got them at rockauto in the literature section of your car on dvd for cheap.
Bobs2008Civic
13
Aug 9, 2017 05:33 AM
billtmore
Honda Fit
Jul 29, 2017 06:19 AM
Robert04accord
May 29, 2014 04:39 PM
PL_RACER
Jul 24, 2012 07:20 PM
23LX23
Jul 17, 2010 10:30 AM
