*Brand new* H22 Turbo Build Partout (Laskey, AllInFab, Sheepey etc)
Old Jul 3, 2016 | 09:28 AM
chris3385's Avatar
Default *Brand new* H22 Turbo Build Partout (Laskey, AllInFab, Sheepey etc)
Bottom end is a H22 block Benson sleeved using a H23 Crank, Pauter Rods, CP Pistons assembled by Laskey Racing. They told me it was good for 850whp. The spec sheet with my pics. $3000
Brand new 0 mile H22 trans and changed the 4.266 FD to a little longer 4.06 ratio and installed an MFactory LSD, Pro Series carbon synchros and hardened sleeves. Assembled by Dave at synchrotec transmissions $2000
Have Sheepey Bottom mount turbo manifold, down pipe, dump tube. Sheepey 700whp intercooler kit, turbo smart blow off valve and Wastegate $2500
Custom built turbo by STC, called the Predator. $1100
Custom all in fab h22 intake manifold, with custom fuel rail, has bungs for secondary injectors and a 90mm mustang flange. $1350
Also ktuned shifter box and custom ktuned race spec cables made for the h22. $1000 with billet trans bracket and shifter stops.
90mm ktuned throttle body $350
Rywire tuck harness and charge harness for 95 prelude H22. $700
Aem v2 ecu for 95 prelude $ 1300
All in fab tucked radiator setup with -16an fittings welded on brand new thermostat housing and water neck for H22. $700
I've got lots more and everything is brand new in box. Act clutch and flywheel, skunk2 pro 1s with springs, retainers, valves, ati crank pulley, ks balance shaft delete kit, ks belt walk eliminator, ks manual tensioner. Brand new oem oil pump, water pump and timing belt. Id1000 injectors
adult photo sharing
Old Jul 6, 2016 | 05:41 PM
Ajbengee's Avatar
Default Re: *Brand new* H22 Turbo Build Partout (Laskey, AllInFab, Sheepey etc)
im interested in a turbo kit for my h22,bottom end built by laskey also, what else would I need if I got ur package for $2500?
nosmark21
Apr 13, 2015 07:44 PM
DxTrix
Jul 9, 2013 07:35 PM
DxTrix
Jul 5, 2013 12:59 AM
95boostedh22
May 25, 2008 07:19 PM
bb4ninja
Sep 26, 2005 07:09 AM
