Analyze my 1/4 mi pass in my turbo civic....
Old Nov 7, 2002 | 06:46 PM
boostin4drcivic's Avatar
Default Analyze my 1/4 mi pass in my turbo civic....
ok heres my info:
5th gen 4dr EX with d16z6, greddy 15G turbo, greddy small FMIC, turbo xs type S bov, turbo xs mbc, 2.25" catback, stock cat, stock inj, stock fuel pump.
boost @ 8psi, but leaking back down to 4.5/5psi around 5500rpm:
wheels were heavy *** 17" ADRs with prolly around 28 psi in em (40 series):
reaction .725
60ft 2.439
1/8 mi 10.04 @ 72.61 mph
1/4 mi 15.43 @ 90.51 mph
this time is very bad considering most people are at least in the high 14s with theyre greddy turbo civics. wats my problem here?? do u think i couldve improved on this somehow?? wat do i seriously need to get these times down?? oh yea, i woulda raced on my steelies, but the tires are cheap and bald. i was pulling 2.6 60's on em so they had to be retired..hehe!! can i put some slicks or drag radials on these 14" steelies?? how much would they be? thanx
Old Nov 7, 2002 | 08:36 PM
Broken Gearbox's Avatar
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (boostin4drcivic)
get a new clutch...and you should also get rid of that 2.25 catback and get a 3" inch catback with a test pipe with slicks and a new catback and clutch u should hit atleasts 14.9s
Old Nov 7, 2002 | 10:36 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (i NEED a S O H C)
I'd say another reason is your 17" tires as well, with that much unsprung weight and rolling resistance, you're bound to be a bit slower. Definately get a better clutch, and exhaust as well. Also I think I;d be looking at why you are bleeding away half of your boost as well.
Clayton
Old Nov 8, 2002 | 01:35 AM
AussieK24's Avatar
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (Clayton)
Loose the rims. 14's or 15's with DR's will get you into 14's altho your mph is not real strong
Old Nov 8, 2002 | 05:34 AM
civic disobedience's Avatar
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (b16a4me)
what kind of rpm are you launching at?
are you heating up the tires good? (burnout)
what tire presure?
I went from a 13.989 to a 13.074 in my turbo hatch, just by working out some issues with the tires, and they are crappy street tire...
I'm running 15 psi in the tires, and 7psi in the motor...BTW
Old Nov 9, 2002 | 10:07 AM
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (civic disobedience)
aight...as far as the clutch, i do have a better clutch. i have a centerforce stage II which has 60% better holding capacity than stock so no problems there. i guess i could use a test pipe which im gonna be ordering soon. as far as the 17s..i didnt have any other rims to race on at the time. what drag radials will fit stock 14 inch steelies?? lemme know.
Old Nov 10, 2002 | 11:29 AM
Old Nov 11, 2002 | 09:13 PM
tonydatyga's Avatar
lose the exhaust (open header), get some steelies w/ any rubber(glass tires will do better than the 17"adrs ), fix the boost leak and work on your 60'. It needs some work and your weak trap isn't helping you at all. Fix the leak b/c its probably ******* up your A/F and hurting you more than just low boost.
Old Nov 12, 2002 | 02:36 PM
how much do u think the stock cat is holding me back?? how much time would i lose if i get a test pipe on there and take off the cat?
Old Nov 19, 2002 | 05:22 PM
Old Nov 20, 2002 | 07:38 AM
UNDER PRESSURE's Avatar
You'll feel the power right about 4000rpm, Other than that I say you should sell the 17's and buy some 15in. rotas.
Old Nov 20, 2002 | 04:41 PM
HXMan's Avatar
Yea, your MPH is low, something seems to be wrong.
My friend has a junkyard turbo setup on a 4dr 90? Carolla. He was trapping around 92mph with 17's....you should be faster.
I would get some serious tuning, and make sure your engine is ok.
Old Nov 20, 2002 | 05:29 PM
D-Man's Avatar
reaction .725
60ft 2.439
check all your turbo piping connnections,replace all the clamps with heavy duty T bolt clamps like the ones turbonetics sell.
Old Nov 20, 2002 | 11:14 PM
JdmVetteEater
Guest
Posts: n/a
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (D-Man)
my boy has a 97 ex with greddy basic kit, with 3 inch exhaust 8 pounds... w/ slicks 13.01
Old Nov 23, 2002 | 11:21 AM
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (JdmVetteEater)
yea i think my trap is low because im losing my boost on the top end. i shouldve actually shifted earlier than redline since i was loosing it, but i didnt know wat the hell was going on and i only got three runs in. ill be running the next time without a boost leak and on some steelies with at least some decent street tires if not drag radials and a test pipe. the silicone hoses on my IC piping are beat, so i think thats prolly where my leak is coming from. so wat are the best drag radials???
Old Nov 23, 2002 | 08:05 PM
nsxmatt's Avatar
Your "boy" needs to post a time slip cause that's BS. Not with a stock motor with a stock greddy kit.
For you
Old Nov 23, 2002 | 09:38 PM
Tofurky's Avatar
hey jdmvetteeater... you might consider changing your name... i don't know too many vettes that run slower than 14.9
Old Nov 23, 2002 | 10:32 PM
DaNish's Avatar
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (Ruckus138)
like everyone else said...
17s are slowing you down, put some nice BF Goodrich Drag Radials on those 14s...
stock cat is holding you back a lot too
anyone else think 8psi is a little much for stock fuel on a sohc?
Old Nov 23, 2002 | 11:11 PM
Tofurky's Avatar
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (X DaNish X)
yes- definitely a bad idea
Old Nov 24, 2002 | 02:33 PM
8psi is fine with my ride....i run rich as **** actually at 5.5psi with the blue box, so turning it up to 8psi leaned it a little whcih was actually a blessing although its still rich. i run so rich, my rear bumper is always covered in black from the license plate over.
Old Nov 24, 2002 | 04:01 PM
nsxmatt's Avatar
If your running that rich then you have problems. Are you burning any oil? That can cause alot of black builup on the back of the car.
Old Nov 28, 2002 | 03:43 PM
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (nsxmatt)
this black buildup didnt happen until this stupid blue box was put into use on my ride. at some points it actually bogs when on the gas slightly when it dumps hella fuel out. but anyway, i dont really burn any oil other than a normal amount for a car with 90k miles on it.
Old Nov 29, 2002 | 03:12 AM
Mista Bone's Avatar
D Tranny Guru
you need a $10 test pipe made from pieces at autozone.
You'll likely seen me run at Ricewater, I mean Edgewater.
Old Nov 29, 2002 | 10:29 PM
Default Re: Analyze my 1/4 mi pass in my turbo civic.... (Mista Bone)
ya i have actually seen u run at Crap-Water a few different times. ur car is ****** fast. i thought u had a swap though...i never looked under ur hood cuz i knew that without a turbo, u had to be running a DOHC something to be getting times like that. ah well...the things u dont know...
Old Nov 29, 2002 | 10:35 PM
Mista Bone's Avatar
D Tranny Guru
The guys with the $6000 swaps really hate me.
Slicks, tuning, and driving. Nothing really special, I've just honed my drivign skills in MY CAR. I've made over 600 passes in it. Practice!
Btw most of the passes came before the "ricers" invaded Egdewater. I was getting 10-12 passes a night, never more than 2 lanes full for the street tire cars. Now your lucky to get 5 passes. I usually goto Tristate now. Closer, less cars, WAY better traction!
