yea this headgasket replacement looks just fun...
Old Nov 7, 2002 | 06:30 PM
BoostedH23a1's Avatar
Default yea this headgasket replacement looks just fun...
2psi and a blown head gasket wtf else can u ask for?
Old Nov 7, 2002 | 06:32 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: yea this headgasket replacement looks just fun... (BoostedH23a1)
well... did you at least give it hell til the headgasket went?
Old Nov 7, 2002 | 06:37 PM
Default Re: yea this headgasket replacement looks just fun... (Boosted97Lude)
2psi man..
Old Nov 7, 2002 | 06:40 PM
Boostless97Lude
Guest
Posts: n/a
2psi man..
Old Nov 7, 2002 | 06:49 PM
just got it runnin
Old Nov 7, 2002 | 08:09 PM
93 VTEC's Avatar
did you check the mating surfaces with a known true straight edge before assembly?
Old Nov 7, 2002 | 10:37 PM
mitsuman's Avatar
Default Re: yea this headgasket replacement looks just fun... (93VTEC)
damm that sux ***. how long were u boosting for?
Old Nov 7, 2002 | 11:07 PM
Import RP's Avatar
Dang, that shouldn't have happened...
Old Nov 8, 2002 | 04:09 AM
apexii's Avatar
How can yo regulate 2psi? Do you have a 2pound spring?
Old Nov 8, 2002 | 05:55 AM
Default Re: yea this headgasket replacement looks just fun... (apexii)
i have my deltagate at 4 psi. i dont know how the hell it stops there but i have the bolt backed all the way out. and i havent boosted more than 3 psi. still messing with ****...
Old Nov 8, 2002 | 08:07 AM
PrecisionH23a's Avatar
did you try the compression test yet? Are you mixing oil and coolant?
Old Nov 8, 2002 | 08:09 AM
Default Re: yea this headgasket replacement looks just fun... (GudeH23a)
my friend is on the way with tester.. no oil in the coolant or water in the oil. doenst look the slightest bit milkly in the valve cover either... hmm
u still stopin buy sunday? maybe its just me maybe thats how it always was but the tube is pretty hard to squeze...
Old Nov 8, 2002 | 08:14 AM
yea ill be coming through columbia on sunday, ill stop by. Exactly how much is the hose expanding? Like i said, i had this problem last year and it turned out to be my radiator cap. If you can, do a cylinder leakdown test, its a lot more accurate then a compression test.
Old Nov 8, 2002 | 08:15 AM
i dont have a compressor up here. ill try to go to a gas station or someting and use their air if my friend ever gets here..
Old Nov 8, 2002 | 10:05 AM
damnit ****** lost it. what a douche. anyway anthony do u have one u can bring? mines in beaufort.
Old Nov 8, 2002 | 11:30 AM
the one i have is up in clemson. if you go to autozone i THINK they will rent them out to you. just put down a payment and youll get it back when you return the tool. call the local parts stores, they should be able to hook you up.
Old Nov 8, 2002 | 11:42 AM
well i got a new upper radiator hose and its not expanding but its still kinda hard to squeeze. maybe its just me... car is still haulin ballz
lakerschamp2000
Apr 20, 2009 10:51 AM
an2ny888
Jul 4, 2008 07:40 AM
Shiftandgo
Sep 4, 2007 01:18 PM
SiRkid
10
Mar 6, 2007 10:08 AM
underpressure02
Apr 25, 2006 06:55 PM
