Occasional intermittent jerking hesitation at high speed
Old Jun 27, 2016 | 06:20 AM
Farby100's Avatar
Default Occasional intermittent jerking hesitation at high speed
2001 Accord manual 5-spd 2.3L with 215,000 miles. Problem occurs only at highway speeds (65-80 mph) very occasionally once or twice on a typical 300 mile route. No loss of electrical, lights, etc. Just a single split-second shuddering jerk or hesitation. Tach rpm doesn't change - steady at 3100 rpm. All repairs within past 25,000 miles including: timing belt, tension controller, O2 sensor, throttle body idle control valve, alternator, spark plugs/wires, and power clean injectors. Just passed emissions inspection. I drive 300-mile each way every weekend on Interstate and this has been happening once or twice each way for a couple months. Any help?
Old Jun 27, 2016 | 04:35 PM
tamboo's Avatar
10 Year Member
Default Re: Occasional intermittent jerking hesitation at high speed
fuel pump starting to bite the big one is my wild *** guess.
Old Jun 27, 2016 | 10:49 PM
holmesnmanny's Avatar
My first guess would be the main relay but it could be the coil going out as well.
Old Jun 28, 2016 | 05:47 AM
Farby100's Avatar
Hi Tamboo and Holmesnmanny, many thanks for suggestion. My Honda guy suggested ignition coil also (and replace fuel pump relay and igniter all together). That might explain why CEL doesn't come on and it only occurs after car running a highway sppeds for about an hour. EGR valve was recently replaced so that not the problem. I will know by this weekend if it still happens and post follow up.
Old Jun 28, 2016 | 04:14 PM
tamboo's Avatar
10 Year Member
all 3 will bite your *** eventually, i carry spares with me just in case.
if the tach jumps all over the place it's icm.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Jun 30, 2016 | 01:15 PM
Farby100's Avatar
Since no CEL ever comes on when this happens, and never on initial start up, happens after hour of driving (on highway), I got the original ignition coil, igniter, and fuel pump relay replaced. I will know by tomorrow if that solved the problem. Thanks for all the suggestions.
Old Jul 5, 2016 | 01:21 AM
Noor Cabir's Avatar
5 Year Member
So any news ? about ur problem ? My Civic 04 D17a Manual is Doing same **** !!
I already change , TDC camshaft Sensor , New igntion , new petrol pump , .. today im going to search the main relay .. its a bite harder to find it .. and the fuel pump relay will change today..
Tampacb7813
Feb 4, 2020 06:43 PM
ncstater6b
Apr 16, 2010 08:53 PM
drumminforev
Jul 6, 2006 10:40 PM
One Slow Lude
Feb 13, 2003 01:57 PM
92TypeR
Apr 3, 2002 07:41 PM
