New Squeaky Brakes on 2010 Honda Accord
Had my friend, who I found out later has little Honda experience, put new rotors, pads on front and back, and calipers on just back of my 2010 Accord (4cyl). Now when I drive along car makes clink sounds on all four wheels when I drive and or hit bump. But sound goes away when I step on the brakes lightly. I'm swaying with cause being loose pads. Is their anything special you need to do on 2010 Accord to make breaks quiet when installing. double check clips. Any suggestions.
Cool Cool Island Breezes. BOY-EE
Lol there's nothing special about Accord brakes.
Your friend probably forgot to tighten the caliper or brackets. Or forgot to install the brake pad hardware.
Check the bolts first. The caliper bolts are M8 bolts. So don't go insane tightening them to a ridiculous amount. IIRC, 25-30LB is correct.
If the bolts are already tight, check for missing pad hardware. Snap a picture and post it if you're unsure.
carid
Feb 8, 2016 03:09 AM
