New Master Cylinder
My master cylinder went out on my EG, so I am in need of a new one. The only problem is I can't find the OEM Nissin anywhere. Is there any other brands of new or refurb ones that anyone would recommended?
Thanks
Thanks
brake or clutch? The A1 Cardone brake reman master cylinders are normally an OEM Nissin. Other than that you can try Beck/Arnley. It wont be stamped Nissin, but they're decent quality.
Adler brand box is OEM Nissin brand inside. Still pretty expensive @ $70-80 but will save you around $50 over the Nissin box.
The NTP brand one looks to be an OEM Nissin unit without the Nissin name embossed into it. Might be worth a try if you don't absolutely need the name. Personally I want mine to say Nissin on the side.
Do you know which size you need? EG's are usually 13/16" (clear reservoir), but there is also some with 7/8" (blue reservoir). There also different ones for ABS cars if you have that. Do you have a brake swap? Let us know.
pcguy760
Apr 13, 2011 02:32 PM
lmike6453
Dec 11, 2007 11:50 AM
RineRacing
Feb 22, 2005 11:20 AM
