Please help 99 accord Master clutch- install issue
Old Jun 22, 2016 | 10:42 AM
westcoastaccord's Avatar
Default Please help 99 accord Master clutch- install issue
Hello everyone
Car: 1999 Accord LX 5 speed manual transmission 4 cylinder
Problem: need to replace the master clutch cylinder and as Ive been told the main hydraulic line at same time.
I purchased a aftermarket clutch cylinder, installed it but CANT get the freaking hydraulic line to seat perfectly and The PIN. Cant get the stupid PIN to slide all the way in. Ive been told that the cylinder and the line has to be changed at same time apparently for this reason.
I'm thinking I can get a aftermarket steel braided hose that will allow me more flexibility in the tight space as well as attaching the line AND pin then swiveling/ flexing it back into the tight space ( is there a trick to inserting the pin back in?)
Ive looked online but cant find anything for a 1999 Honda accord..
FYI: Honda says to replace the master clutch cylinder and the line as well as the slave at same time... but for parrox 200 each part not including labor.. seriously!!!!
can someone help.. please!!!!!
Old Jun 23, 2016 | 12:45 AM
holmesnmanny's Avatar
Default Re: Please help 99 accord Master clutch- install issue
You don't need to change any clutch line for any reason. People do it because they've been told that somehow it helps the clutch feel. If it's leaking change it, if it's not don't change it.
Just change the master cylinder and slave cylinder and you'll be fine.
Old Jun 23, 2016 | 03:52 PM
Can you make a video or take some detailed pics.
Old Jun 24, 2016 | 12:34 PM
Ill make the video and pictures tomorrow morning as I am currently unavailable to access the 1999 accord LX 5 speed
Thank YOU for responding.. YOU are one cool cat!
ns-export
Oct 22, 2017 08:45 AM
Accord3
Jun 30, 2015 11:06 PM
Crazydad
Oct 30, 2013 10:51 PM
ZMan3000
May 21, 2008 11:53 AM
