broken bumper to frame bolts
Old Jun 22, 2016 | 10:33 AM
towncarblue's Avatar
Default broken bumper to frame bolts
I have a 2007 accord sedan lx
My vehicle was involved in an accident
I went to a junkyard and bought a steel bumper. While taking out the one in my car
One of the nuts stripped and another one was so rusted that it snapped off.
the bolt is attached to the frame and the nut is what i have to remove.
I don't know what to do?
The bolt itself seems to go somewhere in the frame?
some pics
passenger side left bolt broken off
http://i261.photobucket.com/albums/i...620_091723.jpg
drivers side right nut stripped
http://i261.photobucket.com/albums/i...620_091733.jpg
Old Jun 23, 2016 | 12:40 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: broken bumper to frame bolts
The links do not work for me, so can't see what you're dealing with.
Old Jun 23, 2016 | 07:28 AM
IMG_20160620_091733.jpg Photo by towncarblue | Photobucket
Old Jun 23, 2016 | 09:48 PM
Shit Posts: 15
10 Year Member
The studs(you refered to as bolts) have to be drilled out and possibly tapped.
Easier to drill it out when the whole support is off.
The stripped nut will be tough.
You could drill though the center till the nut breaks off and remove the studs with the support off.
Or
Use a small angle grinder that will fit in there and grind the nut off.
The studs just screw into the frame. They sort of guide the support onto the car, so it makes screwing the nuts on easier.
Old Jun 24, 2016 | 12:33 PM
so..
i have to remove the broken stud.... { using a bolt extractor ? }
after i remove the studs get a new stud form home depot ????
i thought that the stud was just a hole like wheel studs . i did not know it was tapped.
Old Jun 27, 2016 | 12:46 AM
Shit Posts: 15
10 Year Member
Sorry, now I am not to sure how the stud is held on, on your car.
It may just be welded to the frame, or be threaded into the frame.
50/50. The picture where your stud broke off looks like there are thread on the frame for it tho.
Yes, use a bolt/screw extractor kit to remove the broken studs if they are screwed into the frame.
I wold call honda dealer and see if they sell the correct stud/nut, not get one from home depot. Could also used a bolt to bolt up the suport instead of stud/nut.
Once you get the studs out, use a thread chaser to clean up the threads if there are threads.
Hope this helps.
Old Jul 8, 2016 | 01:51 PM
94EG8's Avatar
Seagull Management
You probably need parts 65619-SDA-A00ZZ, and 65669-SDA-A00ZZ. They aren't worth much at all new from your local dealership.
Old Jul 27, 2016 | 08:37 AM
do i need to weld those in ?????
or are they bolt ons ?
mrandradej
Honda Civic (2001 - 2005)
Jul 14, 2014 09:51 AM
RedEG8
12
Dec 12, 2008 11:53 AM
HomeDepotMade
Jan 21, 2006 12:39 PM
. O M E G A
Oct 17, 2005 01:45 PM
