Street Turbocharged GSR?
Old Jun 21, 2016 | 02:40 PM
egsidev's Avatar
Default Garret or Precision?
Set up
1993 Si hatchback
Super tech valvesprings & retainers
81mm CP Pistons
Eagle H beam rods
ACL Bearings
1000cc iD injectors
iD Fuel pump
Stage 3 Comp clutch
LS Crankshaft
Skunk2 Pro series ported 70mm intake manifold
BWR 70mm Throttlebody
Hondatas300 v3 boost by gear
3 inch exhaust
Moroso tapped oil pan
New everything else (oil pump. water pump. thermal gaskets. etc)
Question, what is a good turbocharger to grab? Just want to hear opinions on a turbo that's capable of holding and putting out this power. This is mainly a street car, but will be at the track occasionally. Hoping to get around to 500hp. Thank you.
Old Jun 21, 2016 | 06:36 PM
boosted94gsr's Avatar
Default Re: Street Turbocharged GSR?
TR3030R "VelociRaptor" turbocharger - Cartridge & Cover
Check this build thread
https://honda-tech.com/forums/forced...12whp-2991155/
Old Jun 22, 2016 | 06:45 AM
Dark_Teg's Avatar
TR3030R is the ultimate at 500whp. A GT3076R would do pretty damn good as well.
boosteddev
Jul 26, 2016 07:23 AM
SergieL
Apr 23, 2015 03:55 PM
slammed101
May 23, 2014 10:53 PM
jonestuner
Aug 23, 2007 11:51 PM
